POV-Ray : Newsgroups : povray.beta-test : beta 32 - buglist Server Time
16 May 2026 01:40:21 EDT (-0400)
  beta 32 - buglist (Message 1 to 10 of 20)
Subject: beta 32 - buglist
Date: 5 Apr 2009 19:02:44
Message: <49d93894@news.povray.org>
beta32 bugs
In windows versions the controls for the render window are non-functional.
(Keep above main, Get focus on creation, and Hide when minimized)
Using facets as a controlling pattern for a normal map results in an
unspecified fatal error, this should be caught at parse time to give a
specific error.
Malformed nested #declares are not caught at parse time, instead they can
terminate inside following control structures, causing some objects not to
render.
Overlapping partially transparent objects can result in speckled shadows.
Rays cast at coincident surfaces should return one of the two textures,
and not "leak" untextured rays.
Texture maps containing reflective textures may cause an exception and
full crash, w/ optional dump.
Partial transparency can cause blocky (32x32) blotches in transparent
regions.
Array.inc and subsurface.pov are in read only mode.
In Vista (x64) the POV (x64) installer fails to ask for admin privleges,
so the program files end up in
C:\Users\%name%\AppData\Roaming\POV-Ray.
After getting install privleges they should end up in
C:\Program Files\POV-Ray
The modifiable files end up in C:\Users\%name%\Documents\POV-Ray
as intended. It's usable this way, just unexpected.
Subject: Re: beta 32 - buglist
Date: 5 Apr 2009 21:13:59
Message: <49d95757$1@news.povray.org>
Oops, that's 3.6 not Beta.
Date: 6 Apr 2009 00:25:00
Message: <web.49d983871eef0732cac4259f0@news.povray.org>
My 3.6 works fine - I just tested them.  It's a self-compiled version but IIRC
I'm using the original editor dll.
Charles
Date: 6 Apr 2009 06:41:30
Message: <49d9dc5a$1@news.povray.org>
>> > non-functional.
> IIRC
> Charles
Hmm, I did observe this today, hmm let me check...
I think what is going on is that you need to exit for the changes to take
effect, so it can appear that the behavior isn't right.
Date: 6 Apr 2009 08:30:34
Message: <49d9f5ea@news.povray.org>
Is this when you select "install for all users"?
-- Chris
Date: 6 Apr 2009 11:25:22
Message: <49da1ee2@news.povray.org>
> render.
  Can you give an example of this?
  The way povray parses SDL, especially things like nested declares, may not
always be completely intuitive, but not necessarily buggy.
Date: 6 Apr 2009 17:00:29
Message: <49da6d6d@news.povray.org>
Tim Attwood nous illumina en ce 2009-04-05 19:02 -->
> beta32 bugs
> specific error.
> render.
> regions.
The ini files are replaced with every version change.
You loose any change that you may have made to them.
After any new version install, you have to go back and remake any customization,
including library paths, permited output path, image file format, display gamma
settings, image gamma, and such.
I believe that banking institutions are more dangerous to our liberties than
standing armies. Already they have raised up a monied aristocracy that has
set the government at defiance. The issuing power should be taken from the
banks and restored to the people to whom it properly belongs.
Thomas Jefferson
Date: 6 Apr 2009 17:20:00
Message: <web.49da70fc1eef0732bda078810@news.povray.org>
> beta32 bugs
trace() and inside() on julia objects still crash POV...
Cheers,
Edouard.
Date: 8 Apr 2009 15:19:00
Message: <49dcf8a4$1@news.povray.org>
No, install for single user...
Date: 8 Apr 2009 16:05:23
Message: <49dd0383$1@news.povray.org>
> not
Sure, I realize it's been this way for a while...
essentially since it's ok to have other declares and
partial control structures inside of a declare there's no
check being done inside the declare until it is used.
In this example if Wierd contains the code up until
the pass_text object, then the parsing should fail
when the first #end is parsed, instead the #end is
matched to #while inside of the value of the Wierd #declare.
// misformed #declare
#declare Weird = #declare Aval = 1;
// other properly formed statements
#declare PigVal = pigment {rgb <0,0,0>};
#declare ObjVal = sphere {<0,0,0>,1};
#if (true=true)
#local c=0;
#while (c=0)
// this object ends the misformed #declare and doesn't render
object {pass_text}
// this object renders normally
object {fail_text}
#local c=1;
