POV-Ray : Newsgroups : povray.beta-test : beta 30 Pause broken when animation rendering Server Time
26 Mar 2026 16:13:47 EDT (-0400)
  beta 30 Pause broken when animation rendering (Message 1 to 5 of 5)
Subject: beta 30 Pause broken when animation rendering
Date: 14 Jan 2009 20:53:36
Message: <496e9720$1@news.povray.org>
This seemed a familiar problem from the past but I didn't find any reference
to it here, except for changes.txt stating beta 4 had improved cancel/pause
(possibly something related in beta 20 too?).
There could be some difference between parsing and rendering when Pause is
used, but I experienced both cause POV to stop without any error messages.
Must exit and wait for Windows to ask what to do.
Not getting the same when non-animations are Paused, so that seems OK.
And, strange coincidence or not, I was going to check this in
3.6.1c.icl8.w32 and it won't even start animations. I tried one as simple as
this to find out if it always happens:
//cmd:-w320 -h240 -ki0 -kf1 -kfi1 -kff50
sphere { <1-clock,0,3>, 1 pigment { rgb 1 } finish {ambient 1}}
Haven't done this using my other computer with XP so this was in Vista.
Fairly certain this wasn't happening in times past.
AMD Turion X2 dual core processor, if that matters.
Subject: Re: beta 30 Pause broken when animation rendering
Date: 14 Jan 2009 22:35:00
Message: <web.496eae55227a5eedc5ec9c90@news.povray.org>
I'm a afraid i can't help here.
> Bob
However, I do know how to solve this! =)  All you have to do is go to the
properties of the "pvengine.exe" and under the compatibility tab you must
checkmark "Disable visual themes".  This hopefully helps.  Let me know if it
doesn't and maybe I can help further.  (I'm becoming fairly proficient with
fixing Vista compatability because of all the practice I get from using so many
"apparently" incompatable programs)
Bridgeofstraws
Date: 15 Jan 2009 00:10:01
Message: <web.496ec3ff227a5eedf434b86a0@news.povray.org>
Oddly, I remember doing this for Beta 29 but not for Beta 30.  I just check and
the compatibility option isn't check yet I'm no longer freezing with the +KFF
option like I did before.  I wonder if Vista remembered the old setting?
Date: 15 Jan 2009 02:32:40
Message: <496ee698$1@news.povray.org>
"SafePit" <ste### [at] reids4funcom> wrote in message
news:web.496ec3ff227a5eedf434b86a0@news.povray.org...
>> it
>> with
>> so many
> check and
> +KFF
I wouldn't think so, not since you must uninstall before doing a
reinstall... but I sure don't know about all that for sure.
I recall that trick to disable themes for whatever reason (been so long
ago!) but hadn't thought to try it. Doing so now only managed to make it
possible to Stop the render and close the program normally, which I guess
means something. No change about the Pause locking up permanently.
I noticed the timer and pixel count continues until stopped, and the menu
bar blinks very slowly.
Compatibility changed to XP (SP2) and disabled themes only makes for a
different appearance of the toolbar, unfortunately not how the Pause works
so that won't help me. Will be a curious thing if it happens with mine and
not other people.
Thanks for the suggestion nonetheless.
Date: 15 Feb 2009 07:03:48
Message: <499804a4@news.povray.org>
Thanks for pointing this out: I've been able to replicate it. I'll design a
more robust system of handling all these buttons for a later beta (not 31).
-- Chris
