POV-Ray : Newsgroups : povray.beta-test : Chasing down a radiosity bug Server Time
10 Jun 2026 18:51:35 EDT (-0400)
  Chasing down a radiosity bug (Message 1 to 4 of 4)
Subject: Chasing down a radiosity bug
Date: 11 Apr 2008 13:45:22
Message: <47ffa3b2@news.povray.org>
So,
I imported a mesh tree (from LightWave, through PoseRay), and attempted
to render it with radiosity. Wouldn't you know it, there was that
unfortunate bug resurfacing, causing certain polygons to render black
with only a few light sparkles as a poor concession for such a great
lack of result.
Tracking down the reason, I concluded that the main contributing factor
was surely the application of a UV-mapped texture. Removal of said
surface with the application of a cheap substitute brought radiosity
back in full force. It's a quick fix which leaves me without the benefit
of conforming UV-mapped textures.
POV-Ray 3.7b25
WinXP Home
Submitted for your consideration~
Sam
Subject: Re: Chasing down a radiosity bug
Date: 12 Apr 2008 07:25:00
Message: <web.48009ad7bca6a28b7d55e4a40@news.povray.org>
[To avoid a beating, I state here and now for the benefit of anyone it might
concern that I fully understand that radiosity in 3.7 is alpha quality only. I
will not respond to comments that do nothing but point this out. I'm doing
nothing but investigating the only major issue I've found with it in my
renders. It's not as if I've shot your dog. Ta]
I wonder if it's connected with the apparent radiosity/UV-mapping problem
apparently demonstrated by the appended scene. I had a problem with polygons in
uv-mapped meshes seemingly being illuminated by ambient light sources even when
they should be shadowed.
After some work I found that this particular problem at least is not
mesh-specific, and in the scene below you can see that the inner, ambient green
sphere, is (according to 3.7 radiosity) managing to illuminate the exterior
surface of the outer, diffuse-shaded sphere.
It only happens (that I've found) if you place the uv_mapping keyword outside
the pigment/normal definition. If, in the scene below, you comment out the
existing uv_mapping line and uncomment the uv_mapping line in the pigment, you
get a UV-mapped pigment but without the radiosity artefacts.
I am investigating in the code but have not had much time; so far all I've found
is that the UV mapping for texture and for pigment get evaluated in different
places in the code (surprise! no) and that they probably end up producing
different perturbed points at which radiosity is sampled. I have not had time
yet to work out whether this actually means anything.
Tom
///////////////////////// SDL BEGIN
sphere {
  0, 1
    pigment { green 1 }
    finish { ambient 1 diffuse 0 }
sphere {
  0, 1.5
    uv_mapping
    //  uv_mapping
      checker scale 0.1
    finish { ambient 0 diffuse 1 }
radiosity {}
  location 5*z
  look_at 0*z
///////////////////////// SDL END
Date: 21 Apr 2008 05:19:34
Message: <480c5c26@news.povray.org>
Really, do not bother testing radiosity. Nothing a user can discover is of
_any_ help in getting radiosity working again. Testing it, you are just
wasting your time. Sorry!
	Thorsten
Date: 21 Apr 2008 17:20:19
Message: <480d0513@news.povray.org>
> of _any_ help in getting radiosity working again. Testing it, you are
> just wasting your time. Sorry!
>     Thorsten
Thanks for letting me know! It's hard not to play with it, since I'd
rather not resort to using 3.6 for final renders.
Sam
