When rendering an animation using Beta24 (3.7.0.beta.24.msvc8-sse2.win32) it
refuses to render the first frame if the Initial_Frame=0.
Ini file Example 1:
Initial_Frame=0
Final_Frame=359
Initial_Clock=0
Final_Clock=359
Input_File_Name=earth.pov
Ini file Example 2:
Initial_Frame=1
Final_Frame=360
Initial_Clock=1
Final_Clock=360
Example 1 creates frames earth001.png to earth359.png under Beta24 (359
files)... Under WinPov3.6.1c it correctly renders frames earth000.png to
earth359 (360 files)
Example 2 creates frames earth001.png to earth360.png under Beta24 (360
files)...
Not a major problem in this instance, but I can see situations where it
could cause major headaches.
Rarius
Is no-one going to answer my report... even with a "We know about it, now go
away!"?
Rarius
"Rarius" <rarius [at] rarius co uk> wrote in message
news:478561e3@news.povray.org...
> it refuses to render the first frame if the Initial_Frame=0.
> Ini file Example 1:
> Initial_Frame=0
> Final_Frame=359
> Initial_Clock=0
> Final_Clock=359
> Ini file Example 2:
> Initial_Frame=1
> Final_Frame=360
> Initial_Clock=1
> Final_Clock=360
> files)...
> Rarius
> away!"?
Nope ;-) IIRC it was never documented to work in the first place...
Thorsten
I've penciled this in to look at later. If the behavior is different from 3.6
we may fix it.
-- Chris
>> it
> 3.6
> we may fix it.
I verified this behavior... here's a minimal test scene
// +kfi0 +kff2 +ki0 +kf2 +fn
// animation bug
// first frame may be skipped
// delete old renders first
#default{finish{ambient 1}}
#if (clock = 0)
// should produce "bug_anim0.png"
sphere {0,1 pigment{rgb <0,1,0>}}
#else
#declare check = pigment{image_map{png
"e:\graphics\render\bug_anim0.png"}};
> Ini file Example 1:
> Initial_Frame=0
> Final_Frame=359
> Initial_Clock=0
> Final_Clock=359
> Ini file Example 2:
> Initial_Frame=1
> Final_Frame=360
> Initial_Clock=1
> Final_Clock=360
> files)...
This is fixed in beta 26. Please hammer the animation code for possible
side-effects to animations that use the default start frame number of 1.
-- Chris
