POV-Ray : Newsgroups : povray.beta-test : Animation bug... Server Time
10 Jun 2026 20:18:40 EDT (-0400)
  Animation bug... (Message 1 to 6 of 6)
Subject: Animation bug...
Date: 9 Jan 2008 19:08:03
Message: <478561e3@news.povray.org>
When rendering an animation using Beta24 (3.7.0.beta.24.msvc8-sse2.win32) it
refuses to render the first frame if the Initial_Frame=0.
Ini file Example 1:
    Initial_Frame=0
    Final_Frame=359
    Initial_Clock=0
    Final_Clock=359
    Input_File_Name=earth.pov
Ini file Example 2:
    Initial_Frame=1
    Final_Frame=360
    Initial_Clock=1
    Final_Clock=360
Example 1 creates frames earth001.png to earth359.png under Beta24 (359
files)... Under WinPov3.6.1c it correctly renders frames earth000.png to
earth359 (360 files)
Example 2 creates frames earth001.png to earth360.png under Beta24 (360
files)...
Not a major problem in this instance, but I can see situations where it
could cause major headaches.
Rarius
Subject: Re: Animation bug...
Date: 11 Jan 2008 13:58:01
Message: <4787bc39@news.povray.org>
Is no-one going to answer my report... even with a "We know about it, now go
away!"?
Rarius
"Rarius" <rar### [at] rariuscouk> wrote in message
news:478561e3@news.povray.org...
> it refuses to render the first frame if the Initial_Frame=0.
> Ini file Example 1:
>    Initial_Frame=0
>    Final_Frame=359
>    Initial_Clock=0
>    Final_Clock=359
> Ini file Example 2:
>    Initial_Frame=1
>    Final_Frame=360
>    Initial_Clock=1
>    Final_Clock=360
> files)...
> Rarius
Date: 11 Jan 2008 14:06:31
Message: <4787be37$1@news.povray.org>
> away!"?
Nope ;-) IIRC it was never documented to work in the first place...
	Thorsten
Date: 14 Jan 2008 04:47:30
Message: <478b2fb2$1@news.povray.org>
I've penciled this in to look at later. If the behavior is different from 3.6
we may fix it.
-- Chris
Date: 22 Jan 2008 18:27:45
Message: <47967bf1$1@news.povray.org>
>> it
> 3.6
> we may fix it.
I verified this behavior... here's a minimal test scene
// +kfi0 +kff2 +ki0 +kf2 +fn
// animation bug
// first frame may be skipped
// delete old renders first
#default{finish{ambient 1}}
#if (clock = 0)
// should produce "bug_anim0.png"
   sphere {0,1 pigment{rgb <0,1,0>}}
#else
   #declare check = pigment{image_map{png
"e:\graphics\render\bug_anim0.png"}};
Date: 11 May 2008 05:34:42
Message: <4826bdb2@news.povray.org>
> Ini file Example 1:
>     Initial_Frame=0
>     Final_Frame=359
>     Initial_Clock=0
>     Final_Clock=359
> Ini file Example 2:
>     Initial_Frame=1
>     Final_Frame=360
>     Initial_Clock=1
>     Final_Clock=360
> files)...
This is fixed in beta 26. Please hammer the animation code for possible
side-effects to animations that use the default start frame number of 1.
-- Chris
