POV-Ray : Newsgroups : povray.beta-test : -state at interrupted render Server Time
30 Mar 2026 04:05:31 EDT (-0400)
  -state at interrupted render (Message 1 to 7 of 7)
Subject: -state at interrupted render
Date: 7 Dec 2006 03:28:37
Message: <4577d0b5$1@news.povray.org>
Forgive me if this has been asked before. I couldn't find a mention of it.
When interrupting a render, the output file shows the scene name with -state
added to it, instead of showing the image up to the moment of rendering.
Also, that file may be quite large, so I wondered if this was a (future)
possibility to restart and continue a render at the place where it was
interrupted? That would be very convenient in fact!
Subject: Re: -state at interrupted render
Date: 7 Dec 2006 04:52:09
Message: <4577e449@news.povray.org>
The state file does contain continuation information (amongst other things)
and is used by the continuation feature. Note that this feature already
exists in previous versions, albeit in a more limited form - please see the
documentation for details.
-- Chris
Date: 7 Dec 2006 08:06:52
Message: <457811ec$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> schreef in
bericht news:4577e449@news.povray.org...
> things)
> the
Ah, thank you, Chris!
I have not much used that particular feature. The reason is that I found it
fairly unstable. I have experienced several times the loss of already
rendered parts of a scene by adding +C. I don't remember what the error
message was, or if it was a crash or not. So usually,  I just start again on
the last rendered row (after saving the previous render) and join everything
later on.
So, if the feature is more reliable in 3.7, that would be fine of course :-)
Subject: Re: -state at interrupted render: not working correctly
Date: 7 Dec 2006 08:54:21
Message: <45781d0d$1@news.povray.org>
Well, as far as I can tell, this does not work correctly (or I am doing
something wrong!)
Try this:
- start render of Tango.pov
- stop render at any time before completion
-start render again, with +C in the command line
result: POV-Ray starts parsing indefinitely; you cannot stop the render
anymore; you can only stop it by closing POV-Ray.
Date: 7 Dec 2006 19:52:07
Message: <4578b737@news.povray.org>
Thomas de Groot nous apporta ses lumieres en ce 07/12/2006 08:54:
> something wrong!)
> Try this:
> Thomas
I can confirm that, not only with the latest beta. I need to kill it using the
task manager as I can't just exit POV.
Fully patched Windows 2000 pro sp4.
But I thought YOU did the backups...
Date: 14 Jan 2007 02:05:27
Message: <45a9d637$1@news.povray.org>
>> something wrong!)
>> Try this:
>> Thomas
This has now been fixed.
thanks,
-- Chris
Date: 28 Jan 2007 03:30:49
Message: <45bc5f39$1@news.povray.org>
bericht news:45a9d637$1@news.povray.org...
Thank you indeed Chris! Works perfectly!!
