POV-Ray : Newsgroups : povray.beta-test : Functions more than 65535 Server Time
4 Jul 2026 13:58:53 EDT (-0400)
  Functions more than 65535 (Message 15 to 24 of 34)
Subject: Re: Functions more than 65535
Date: 13 May 2002 02:38:54
Message: <3CDF5F7D.CA29C09C@gmx.de>
Thorsten Froehlich wrote:
> Keep in mind that the "1" and "10" could be expressions and it is also
> faster...  ;-)
I would not mind if you implement this, it certainly has it's uses.  While
you are on it, how about custom vector functions, something like:
function { <x^2, sin(z), z> }
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Date: 13 May 2002 07:15:41
Message: <3cdfa05d@news.povray.org>
In article <3CDF5F7D.CA29C09C@gmx.de> , Christoph Hormann
I am sure some crazy person will figure out some even more crazy applications
Who knows, maybe it already exists somewhere on my and a few other harddisks.
> While you are on it, how about custom vector functions, something like:
Users!  You give them one feature and they start crying for the next! ;-)
Unfortunately, vectors are more difficult to implement :-(
    Thorsten
e-mail: tho### [at] trfde
Date: 13 May 2002 07:24:09
Message: <6f8vdugobfjnf3s055aqfpftva33mgbutt@4ax.com>
On Mon, 13 May 2002 13:15:38 +0200, "Thorsten Froehlich" <tho### [at] trfde>
> for it.  Warp?  W?odzimierz?  ;-)
Question marks. That's what makes people crazy. ;-)
Don't give up. :-)
ABX
Date: 13 May 2002 09:14:30
Message: <3cdfbc36@news.povray.org>
  It would be really useful if you could also specify the operation which
is performed.
  That is, as a sum it is something like:
result = 0;
for(n=initial_value; n<=final_value; ++n) result = result + expression(n);
  This would be much more useful if it were more generic, that is:
result = 0;
for(n=initial_value; n<=final_value; ++n) result = expression(result, n);
if you understand what I mean.
  You could implement a sum, a multiplication or whatever you want.
  It would be nice if the parameters to a function could be vectors as well
as floats. This would be useful in some situations.
Date: 13 May 2002 13:57:53
Message: <3CDFFEA1.EFD098F3@gmx.de>
What did you expect? ;-)
There are already vector functions in form of spline functions, but i
suppose this is something different.
Date: 14 May 2002 01:41:46
Message: <nm81euck3idbv37nb7erl57ilgn3ig8lnt@4ax.com>
Btw such conclusion, have you noticed my hidden request posted somewhere about
gate between functions and polynomial solver ? I told I would try to implement
it in the future but perhaps it already exists on some of your drives... :-)
ABX
Date: 14 May 2002 04:29:58
Message: <3ce0cb06@news.povray.org>
It would have to return multiple results in some cases, which is not really
possible right now...
Once there is a full programming language available in 4.0 I suppose many of
the interesting internal functions can be made available.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 14 May 2002 04:37:42
Message: <7vi1eu8k1r551rrg53o48arjtonfnkv6r5@4ax.com>
On Tue, 14 May 2002 10:29:54 +0200, "Thorsten Froehlich" <tho### [at] trfde>
But knowing max order of polynomial I know max number of roots so can ask for
n-th root. Additional function could return number of roots to check if there
is any.
ABX
Date: 14 May 2002 04:47:58
Message: <bkj1eu4k0ei3hqo426i06t0jnm3gb3t7od@4ax.com>
shader ? raytracer in function VM in SDL ?
ABX
Date: 14 May 2002 09:07:03
Message: <3ce10bf7@news.povray.org>
Why not just call out to Perl and be done. All these hacky quick developed
new languages are a real pain, when Perl already does just about everything
you can want from a proramming language. I think you guys should be spending
time on improving realism/adding features instead of a new programming
language.
Mike
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3ce0cb06@news.povray.org...
of
