POV-Ray : Newsgroups : povray.beta-test : Functions more than 65535 Server Time
25 Jul 2026 08:29:22 EDT (-0400)
  Functions more than 65535 (Message 11 to 20 of 34)
Subject: Re: Functions more than 65535
Date: 12 May 2002 17:32:45
Message: <3cdedf7d$1@news.povray.org>
In article <3CDEDA2C.8504C17C@gmx.de> , Christoph Hormann
<chr### [at] gmxde>  wrote:
> I'm not sure what you mean by 'sum' function
For example allowing functions equivalent to
10
 >  i*2+4
i=1
inside functions, would that help?
    Thorsten
e-mail: tho### [at] trfde
Date: 12 May 2002 17:58:24
Message: <3CDEE57F.29ECF6D5@gmx.de>
> 10
>  >  i*2+4
> i=1
That would be nice but it would not help much in this particular case and
is in fact not necessary since this can already be done using #while
inside functions.  In the example i gave i could have put a 'function {}'
around the while loop, leave out the #declare's and just sum up things
with the loop, this would avoid the recursion problem, but this does not
work if you build several functions in the while loop and don't want to
split into separate loops for speed reasons.
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Date: 12 May 2002 18:00:58
Message: <3CDEE617.73DE8699@gmx.de>
ingo wrote:
> Unless it changes the meaning completely, I think I'll leave out the word
> "recursion", to prevent the idea that recursive functions are possible.
All right.
Date: 13 May 2002 02:19:37
Message: <3cdf5af9@news.povray.org>
In article <3CDEE57F.29ECF6D5@gmx.de> , Christoph Hormann
> inside functions.
Keep in mind that the "1" and "10" could be expressions and it is also
faster...  ;-)
    Thorsten
Date: 13 May 2002 02:38:54
Message: <3CDF5F7D.CA29C09C@gmx.de>
> faster...  ;-)
I would not mind if you implement this, it certainly has it's uses.  While
you are on it, how about custom vector functions, something like:
function { <x^2, sin(z), z> }
Date: 13 May 2002 07:15:41
Message: <3cdfa05d@news.povray.org>
In article <3CDF5F7D.CA29C09C@gmx.de> , Christoph Hormann
I am sure some crazy person will figure out some even more crazy applications
Who knows, maybe it already exists somewhere on my and a few other harddisks.
> While you are on it, how about custom vector functions, something like:
Users!  You give them one feature and they start crying for the next! ;-)
Unfortunately, vectors are more difficult to implement :-(
    Thorsten
Date: 13 May 2002 07:24:09
Message: <6f8vdugobfjnf3s055aqfpftva33mgbutt@4ax.com>
On Mon, 13 May 2002 13:15:38 +0200, "Thorsten Froehlich" <tho### [at] trfde>
> for it.  Warp?  W?odzimierz?  ;-)
Question marks. That's what makes people crazy. ;-)
Don't give up. :-)
ABX
Date: 13 May 2002 09:14:30
Message: <3cdfbc36@news.povray.org>
  It would be really useful if you could also specify the operation which
is performed.
  That is, as a sum it is something like:
result = 0;
for(n=initial_value; n<=final_value; ++n) result = result + expression(n);
  This would be much more useful if it were more generic, that is:
result = 0;
for(n=initial_value; n<=final_value; ++n) result = expression(result, n);
if you understand what I mean.
  You could implement a sum, a multiplication or whatever you want.
  It would be nice if the parameters to a function could be vectors as well
as floats. This would be useful in some situations.
Date: 13 May 2002 13:57:53
Message: <3CDFFEA1.EFD098F3@gmx.de>
What did you expect? ;-)
There are already vector functions in form of spline functions, but i
suppose this is something different.
Date: 14 May 2002 01:41:46
Message: <nm81euck3idbv37nb7erl57ilgn3ig8lnt@4ax.com>
Btw such conclusion, have you noticed my hidden request posted somewhere about
gate between functions and polynomial solver ? I told I would try to implement
it in the future but perhaps it already exists on some of your drives... :-)
ABX
