|  |  | To the Sample Scene File Coordinator
Rendering abyss.pov I noticed the following messages:
File: C:\Programmer\POV-Ray for Windows v3.5\scenes\advanced\abyss.pov
Line: 220
Warning: The maximum gradient found was 2.492, but max_gradient of the
isosurface was set to 1.100. The isosurface may contain holes!
Adjust max_gradient to get a proper rendering of the isosurface.
Line: 246
Warning: The maximum gradient found was 2.406, but max_gradient of the
isosurface was set to 1.500. The isosurface may contain holes!
Statistics for C:\Programmer\POV-Ray for Windows
v3.5\scenes\advanced\abyss.pov, Resolution 640 x 240
Setting the appropriate max_gradients makes the messages disappear
with no obvious image change.
/Erkki
de news: 3c7174f9.123612399@news.povray.org...
Fixed and sent to the scene coordinator.
Thanks for finding this one.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
|  |  | On Sat, 23 Feb 2002 14:05:24 +0100, "Gilles Tran" <tra### [at] inapg inra  fr>
Who is it these days, I lost track. I'm playing a bit around since I
got more memory added and the Balcony scene has lots of problems with
tecent changes. I can fix it but I don't want to duplicate work if
someone else is at it allready.
It was accidental, I saw someone mention its memory use and decided to
test my new memory.
/Erkki Post a reply to this message
| From: Christoph Hormann Subject: Re: (sample scenes) Abyss.pov max_gradient msg
 Date: 24 Feb 2002 05:09:21
 Message: <3C78BBD1.BF566E09@gmx.de>
Rune is the coordinator, but i don't see any problems in balcony.pov right
now, the last change was because of the isosurface syntax change and this
works correctly with beta 11.
Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
|  |  | On Sun, 24 Feb 2002 11:09:21 +0100, Christoph Hormann
Hmm, I must be out of sync then, time to remove and re-install. First
problem is the attempted include of "function.inc" in line 38, if you
have "functions.inc" there I must be back-levelled.
