Couldn't find this in the docs or in a previous posting.
the 'hollow' keyword doesn't seem to work properly in light groups.
if you put the camera inside an object with hollow it renders fine
if you out the hollow object inside a light group, you get the 'camera is
inside a non-hollow object..." warning.
-tgq
In article <3c20ac9a$1@news.povray.org> , "Trevor Quayle"
Please provide a _short_ example.
Thorsten
Odd, I'm not sure what's going on here.
Try the following scene, the camera is not inside the box but is inside the
sphere
1) as is, the scene gives an error even though the camera is inside the
sphere and the sphere is 'hollow' and not inside the box.
2)comment out just the sphere and it's fine
3)comment out just the box and it's fine
4) add 'hollow' to the box and it's fine (the camera isn't even in the box)
5) move just the box outside the light group and it's fine
6) move just the sphere outside the light group and it's fine
hope this helps
-tgq
//start
camera{
location <50,30,50>
look_at <0,0,0>
light_group{
box{<-300,-30,-120> <300,-5.5,120>}
plane{-y 0 hollow}
//end
>sphere
It looks to me like the program needs to determine whether the whole
light_group is hollow or not, and it's doing it in the same way that it
does it for CSG. In a union or merge, the resulting CSG object is hollow
only if *all* the parts are hollow. I.e. substituting "union" or "merge"
for "light_group" in your code gives exactly the same effect.
Mike Williams
Gentleman of Leisure
In article <Y++xgG### [at] econymdemoncouk> , Mike Williams
Yes, because a light_group internally is a (special) union...
Thorsten
e-mail: tho### [at] trfde
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c21f2e1$1@news.povray.org...
> Thorsten
So the 'hollow' in the sphere is ignored because the box isn't hollow?
-tgq
In article <3c21f522$1@news.povray.org> , "Trevor Quayle"
Actually, it might be that only the check fails and everything works the way
it is supposed to. In a future beta light_group unions will automatically
be split and the message will no long appear.
Thorsten
