POV-Ray : Newsgroups : povray.beta-test : Bug stats Server Time
2 Nov 2024 11:26:54 EDT (-0400)
  Bug stats (Message 1 to 7 of 7)
Subject: Bug stats
Date: 4 Dec 2001 13:00:58
Message: <4255SDAiEND8EwFM@econym.demon.co.uk>
When I did software testing for one of the UK high street banks we had a
theory about software bugs. We reckoned that the rate of fixing bugs in
a complex piece of software was approximately linear, but the rate of
finding new bugs decreases because there should be fewer bugs to find
(as long as the attempted bug fixes didn't introduce more new bugs as
side effects). By observing the way the number of known outstanding bugs
decreased over time, we considered it possible to estimate the probable
number of unknown bugs remaining in the system.
So here's the numbers of outstanding confirmed bugs from the various
known bug lists.
        Date            known bugs
        27 Sep          19
        28 Sep          16
         1 Oct          21
        23 Oct          25
         1 Nov          27
        21 Nov          38
        27 Nov          42
         2 Dec          37
        current         42      (list not yet published)
We appear to be moving in the wrong direction.
(That never happened at the bank.)
Mike Williams
Gentleman of Leisure
Subject: Re: Bug stats
Date: 4 Dec 2001 14:05:18
Message: <3c0d1e6e@news.povray.org>
In article <425### [at] econymdemoncouk> , Mike Williams
> known bug lists.
>         Date            known bugs
>         27 Sep          19
>         28 Sep          16
>          1 Oct          21
>         23 Oct          25
>          1 Nov          27
>         21 Nov          38
>         27 Nov          42
>          2 Dec          37
No, not at all.  It is just that the team isn't as fast fixing bugs as they
are reported.  However, the number of bug reports has actually decreased
when you look at the same period of time.  For example, there had been about
20 reports in the first three weeks, but only another 20 in the past six
weeks.  So effectively the rate of new bugs found has slowed down.
Of course, you can't be sure that all those bugs hold up to an
investigation.  Besides, some of the bugs in your list are scene/include
file only...
    Thorsten
e-mail: tho### [at] trfde
Date: 6 Dec 2001 16:52:15
Message: <3c0fe88f$1@news.povray.org>
I don't know.  It seems all hell broke loose when beta 8 was released.  For
a while it looked like you might have to go back to beta 7.
Jim
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c0d1e6e@news.povray.org...
> > known bug lists.
> >         Date            known bugs
> >         27 Sep          19
> >         28 Sep          16
> >          1 Oct          21
> >         23 Oct          25
> >          1 Nov          27
> >         21 Nov          38
> >         27 Nov          42
> >          2 Dec          37
they
about
> file only...
>     Thorsten
Date: 6 Dec 2001 21:17:00
Message: <3c10241e.10059241@localhost>
On Thu, 6 Dec 2001 16:52:14 -0500, "Jim Kress"
I wish I could go back to beta 7.  Unfortunately it has a timeout
and (short of setting my clock every tiem i want to use povray) I
can't run it anymore!
Hmmm.  Any chance of talking the povteam into recompiling beta 7
with a timeout change?  This could be used whilst they fix the
weirdness in beta 8.
Pete
Date: 7 Dec 2001 04:31:48
Message: <3c108c84@news.povray.org>
In article <3c10241e.10059241@localhost> , PeterC@nym.alias.net.almost
The problems in beta 8 are fully predictable.  They *only* involve
functions.  In fact the same problems existed earlier but nobody would
notice because they did only happen with isosurfaces which would cause a
crash when printing max_gradient messages before.  If you apply the
suggested workaround, or if you run only one scene and the restart POV-Ray
you can reliably work around the problem, which is sufficient to not go back
to the previous beta.  Apart from that, it had other problems that have been
fixed in beta 8.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 8 Dec 2001 10:55:34
Message: <3c1237f6@news.povray.org>
When will you post your most recent list?
BTW, the following bugs from your list (and others, not on your list and not
mentioned here) are fixed in the next beta so far:
Bug with intersection stack (with crash)(job000175)
http://news.povray.org/5f13rtc0v0rso4fk7lut5e0980qa9g756b@4ax.com
Alpha problems: text is not antialiased (job000187)
(black objects are not antialiased on Unix and Windows versions, alpha
is not correctly output on Mac)
http://news.povray.org/3bea5a84$1@news.povray.org
Focal blur aperture has no effect with camera types other than the
persective one (job000185)
http://news.povray.org/3bceb66d@news.povray.org
    Thorsten
Date: 9 Dec 2001 01:13:22
Message: <tNnM8AAHRmE8EwsF@econym.demon.co.uk>
I plan to post it about once a week, normally on Mondays.
Mike Williams
