POV-Ray : Newsgroups : povray.beta-test : Improvement suggestion to 6.10.3 Server Time
18 Feb 2026 22:29:36 EST (-0500)
  Improvement suggestion to 6.10.3 (Message 1 to 7 of 7)
Subject: Improvement suggestion to 6.10.3
Date: 16 Oct 2001 12:27:39
Message: <3bcc5ffb@news.povray.org>
I think that the section "6.10.3 Photons and Light Sources" is a bit
confusing because first there's one version of the photons-block inside
a light source and then another.
  It could be better if the first example was changed to:
light_source {
  MyLight
  [light_photon_block]
  Also the 'area_light' switch should be explained.
Subject: Re: Improvement suggestion to 6.10.3
Date: 17 Oct 2001 03:45:53
Message: <Xns913D6354E985Eseed7@povray.org>
>   bit
> inside a light source and then another.
I do not exactly understand what you mean, but after looking at it I
noticed that example and syntax are swapped. The second part should
come first. The first part should be marked as an example. Would this
solve your problem?
Never tried it, so if someone can explain me what it does?
Ingo
Date: 17 Oct 2001 09:10:56
Message: <3bcd8360@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
Allows the area light in a light source to be used instead of its usual
point source.  Not much to explain there I guess, which is probably why it
wasn't.
If there's anything more to it than that it'd be Nathan whom would know.
Bob H.
Date: 17 Oct 2001 15:30:44
Message: <3bcddc64@news.povray.org>
ingo <ing### [at] homenl> wrote:
:>   Also the 'area_light' switch should be explained.
: Never tried it, so if someone can explain me what it does?
  AFAIK photons are by default shot from the location of the light source, no
matter if it's an area light or not. However, if the light is an area light
and you specify 'area_light' in its photons block, then the photons will be
shot from all parts of the area light (perhaps randomly?).
Date: 17 Oct 2001 17:30:17
Message: <Xns913DEF19C7215seed7@povray.org>
> will be shot from all parts of the area light (perhaps randomly?).
That would mean we have a real 'soft light'.
Nathan, can you confirm, please.
Ingo
Date: 18 Oct 2001 02:50:48
Message: <3bce7bc8@news.povray.org>
: That would mean we have a real 'soft light'.
  It means that the caustics will simulate a lot better those of an area
light instead of a point light.
  The 'soft light' part is made by the shadow testing routine, which has
little to do with photons (AFAIK).
Date: 19 Oct 2001 18:53:49
Message: <slrn9t1bj0.ifv.ron.parker@fwi.com>
Not entirely.  It's also a function of the diffuse illumination routine,
which determines the intensity of the light by the angle to the center
of the area light rather than by integrating the illumination over the
entire area of the area light.  Photons might be able to even that out
a little.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
