POV-Ray : Newsgroups : povray.beta-test : Known Bugs Sep 28 Server Time
19 Dec 2025 14:31:58 EST (-0500)
  Known Bugs Sep 28 (Message 1 to 10 of 22)
Subject: Known Bugs Sep 28
Date: 28 Sep 2001 11:21:17
Message: <3bb4956d@news.povray.org>
Here are the known and confirmed bugs as per today. Corrections to the list
are still very welcome.
18077  Blob problem
http://news.povray.org/povray.beta-test/18087/
18089  Blob : Toward a solution
http://news.povray.org/povray.beta-test/18089/
18094  Superellipsoid epsilon to big ?
http://news.povray.org/povray.beta-test/18094/
18105  Additional (?) blob bug
http://news.povray.org/povray.beta-test/18105/
18391  hf_gray_16 + png creates wrong output image
http://news.povray.org/povray.beta-test/18391/
18456  Blob rendering error
http://news.povray.org/povray.beta-test/18456/
18522  Small window title bug
(Title switches back to "POV-Ray for Windows" after minimize or restore. )
http://news.povray.org/povray.beta-test/18522/
18529  16-bit PGM pigment and height field problems
http://news.povray.org/povray.beta-test/18529/
18535  Blend map crash
http://news.povray.org/povray.beta-test/18535/
18565  Radiosity with recursion > 1
(With recursion_limit > 1 clear axis aligned bands appear on the surfaces.)
http://news.povray.org/povray.beta-test/18565/
18577  Rendering animation (MS Windows)
(Message that indicates the frame to be render is displayed AFTER the
rendering.)
http://news.povray.org/povray.beta-test/18577/
18638  Stop during mosaic: crash
http://news.povray.org/povray.beta-test/18638/
18650  sin(X)^sin(X) -> crash!
http://news.povray.org/povray.beta-test/18650/
18672  Bug with parse_string
http://news.povray.org/povray.beta-test/18672/
18740  Spline bug
(The spline path is all wrong when certain time values are used.)
http://news.povray.org/povray.beta-test/18740/
18746  Radiosity crash when user stops render during pretrace.
http://news.povray.org/povray.beta-test/18746/
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Subject: Re: Known Bugs Sep 28
Date: 28 Sep 2001 20:12:12
Message: <3bb511dc$1@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3bb4956d@news.povray.org...
Just found that hf_gray_16 (on) won't allow a render to proceed.  That bug
mentioned was only about TGA file output being okay but not for PNG and with
the Beta 2.  I get the message:
File Init Error: Cannot open output file.
whether png or tga is specified.
Intel opt. Beta 4, WinMe, PIII, 512MB
Bob H.
Subject: Re: nevermind
Date: 28 Sep 2001 23:02:50
Message: <3bb539da@news.povray.org>
Just found a message by Bonsai here from the 24th saying the same thing I
just did about File Init Error.  Ron suggests it would be fixed in Beta 5.
Bob H.
Date: 28 Sep 2001 23:30:28
Message: <slrn9rag2o.6ml.ron.parker@fwi.com>
Or some future beta.  One never knows; I might check it in just after Chris
starts building the beta.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 30 Sep 2001 17:27:02
Message: <3bb78e26@news.povray.org>
You forgot to mention the *sphere_sweep with radiosity bug*
Jonathan
"Rune" <run### [at] mobilixnetdk> ha scritto nel messaggio
list
> 18077  Blob problem
surfaces.)
> rendering.)
> 18740  Spline bug
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 1 Oct 2001 11:23:02
Message: <a1vgrtgkmem30dmqvmd265tulhpivjsb9l@4ax.com>
On Fri, 28 Sep 2001 17:15:53 +0200, "Rune"
Perhaps there is a reason but you attached only one my post.
Here are other not finished with explanation or "will be fixed"
  Crash after constant function
  http://news.povray.org/povray.beta-test/18496/
  Bug with intersection stack (I gave solution)
  http://news.povray.org/povray.beta-test/18696/
  #if inside #if (but Nathan said - no solution anywhere :-( )
  http://news.povray.org/povray.beta-test/18701/
  Another string bug (or even two)
  http://news.povray.org/povray.beta-test/18706/
  Old accuracy bug - perhaps with no chance to fix
  http://news.povray.org/povray.beta-test/18702/
There is also something new from me
  Select within select
  http://news.povray.org/povray.beta-test/18823/
I answered for your request for help
  http://news.povray.org/povray.beta-test/18618/
Have you readed this? Was this helpful ? Should I continue ?
ABX
Date: 1 Oct 2001 14:27:09
Message: <3bb8b57d@news.povray.org>
> one my post. Here are other not finished with
Note:
Only confirmed bugs can get on the list.
You couldn't know this, but for the future, please specify messages this
way:
http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
(The part after http://news.povray.org/ is the message ID.)
I'll add this.
I'll add it.
That's not a bug but a limitation.
I'll add "Crash with long strings, ignore documentation bug report"
This bug doesn't seem to have been confirmed.
This hasn't been confirmed properly.
Yes. Yes. Yes. (Sorry I didn't answer before to that.)
Rune
Date: 22 Oct 2001 05:11:25
Message: <ahn7ttc31av05805lom27csqk778mpdvvl@4ax.com>
On Mon, 1 Oct 2001 20:28:47 +0200, "Rune"
ok.
> way:
where on the www interface I can find it that way ?
> I'll add this.
is seems it's gone for beta 6
> I'll add it.
it still present for beta 6
than I must wait for sources :-(
can anybody confirm this ?
I can confirm that it still present for beta 6
yes, wrong noise generator
ok, I see it is still not finished for beta 6 therefore I'll start
with it.
ABX
Date: 22 Oct 2001 06:47:01
Message: <3bd3f925@news.povray.org>
Just _follow_ the link, at is all you need to do to find it.
    Thorsten
e-mail: tho### [at] trfde
Date: 22 Oct 2001 08:12:42
Message: <q338tt4tlomhlieng38togpei5t3i8phf4@4ax.com>
On Mon, 22 Oct 2001 12:46:59 +0200, "Thorsten Froehlich"
perhaps there is some limitation in my English but I not asked how use
links but how generate link with message ID having opened message via
www interface
ABX
