POV-Ray : Newsgroups : povray.beta-test : Slope pattern Server Time
1 Aug 2026 05:10:12 EDT (-0400)
  Slope pattern (Message 1 to 4 of 4)
Subject: Slope pattern
Date: 23 Sep 2001 15:38:46
Message: <3bae3a46@news.povray.org>
3.5 beta3 Windows
Slope pattern still does not work for slope = 1
See attached scene file, the flat top of the object should be red.
-tgq
camera{
  direction<0,0,1>
  up<0,1,0>
  right<4/3,0,0>
  location <-60,60,-60>
  look_at  0
light_source{
  0
  color rgb 1
  translate<-50,200,-50>
background {color 0}
#declare MD1=
material{
  texture{
    pigment{rgb 1}
    finish{ambient 0.5 diffuse 0.05}
  texture{
    pigment{
      slope y
      color_map{
        [0.5 rgbt 1]
        [1.0 red 1]
    finish{ambient 0.5 diffuse 0.85}
merge{
  torus{20 20}
  cylinder{-20*y 20*y 20}
  material{MD1}
Subject: Re: Slope pattern
Date: 24 Sep 2001 16:42:53
Message: <slrn9qv6mf.pbu.ron.parker@fwi.com>
On Sun, 23 Sep 2001 15:31:52 -0400, Trevor Quayle wrote:
>3.5 beta3 Windows
This is because maps "wrap around" at 1, with the value exactly equal to
1 not being represented in the map.  Something with slope exactly equal
to 1 (well, not really, but you know what I mean) will use the value at the
0 end of the map.
A temporary workaround is to use
      color_map{
        [.000001 red 1]
        [.000001 rgbt 1]
        [0.5 rgbt 1]
        [1.0 red 1]
instead of the color_map you had.  This is technically correct behavior,
but it's worth discussing whether the slope pattern should be an exception
to the rule.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 24 Sep 2001 20:38:49
Message: <3bafd219@news.povray.org>
If this is what is happening then I would support making slope pattern an
exception to the rule, if possible.  That way the pattern would make more
sense as the slope pattern does not wrap around in the way that others may.
If 1 represents the positive perpendicular plane, then it should use the 1
value from the colour map.  In the workaround you proposed, the top is
fixed, but if you look at the bottom of the object (move the camera, don't
rotate the object, or change the direction from y to -y), now the flat
bottom is red where it should be white.
-tgq
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
> >3.5 beta3 Windows
the
> 0 end of the map.
>       color_map{
>         [.000001 red 1]
>         [.000001 rgbt 1]
>         [0.5 rgbt 1]
>         [1.0 red 1]
> to the rule.
1/3}[.5F
opinions
Date: 24 Sep 2001 22:15:47
Message: <slrn9qvq6m.f7.ron.parker@fwi.com>
Good point.   This will be fixed in the next beta.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
