POV-Ray : Newsgroups : povray.beta-test : References to 3.0 and 3.1 in the docs Server Time
15 Jun 2026 01:01:19 EDT (-0400)
  References to 3.0 and 3.1 in the docs (Message 1 to 5 of 5)
Subject: References to 3.0 and 3.1 in the docs
Date: 14 Sep 2001 05:35:32
Message: <3ba1cf64@news.povray.org>
POV-Ray 3.5 beta 2
Some are wrong, others are misleading or just strange.
Note: In most cases all you really have to do is change "is" to "was"...
3.4.13 Text Object
"Now, for POV-Ray 3.0, a new primitive has been introduced that can use any
TrueType font to create text objects."
Also, in the sample code POV-RAY 3.0 is consistently used as the text.
6.11.3.2 Image File Gamma
"The new PNG format files generated by POV-Ray 3.0 overcome the problem..."
6.11.3.3 Scene File Gamma
"Rather than have you change all the scene files to have a single fixed
gamma value (heaven forbid!), POV-Ray 3.0 allows you to specify in the
scene file the display gamma of the system that the scene was created on."
6.2.6 Conditional Directives
"POV-Ray 3.0 allows a variety of new language directives to implement
conditional parsing of various sections of your scene file."
6.1.3.2 Float Identifiers
6.1.4.2 Vector Identifiers
6.1.5.3 Color Identifiers
"This semi-colon is new with POV-Ray version 3.1."
5.2.1 Animation Options
"POV-Ray 3.0 greatly improved its animation capability with the addition of
an internal animation loop, automatic..."
 -- Nikodemus
Subject: Re: References to 3.0 and 3.1 in the docs
Date: 14 Sep 2001 07:42:39
Message: <Xns911C8B799D92Cseed7@povray.org>
I'll see if I can losse all references to version numbers in the docs.
Ingo
Date: 14 Sep 2001 08:05:03
Message: <3ba1f26f@news.povray.org>
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
At least they are easy to find - Just use the search tab, and search for
"POV-Ray 3.0" and "POV-Ray 3.1"
\\ Jon.
Date: 14 Sep 2001 09:40:31
Message: <3ba208cf$1@news.povray.org>
    Aren't some of these true? The conditional directives were "new" in 3.0
weren't they? Perhaps some of these sections can be seen as history.
Date: 14 Sep 2001 09:56:06
Message: <3ba20c76@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3ba208cf$1@news.povray.org...
Hence the original suggestion that the tense be changed, rather than the
wording. Try and keep up, Bill ;)
