POV-Ray : Newsgroups : povray.beta-test : Images overlap insert menu Server Time
19 Feb 2026 12:44:25 EST (-0500)
  Images overlap insert menu (Message 1 to 4 of 4)
Subject: Images overlap insert menu
Date: 7 Sep 2001 19:19:04
Message: <3b9955e8@news.povray.org>
When you have enough items in an insert menu for it to make a new
column, the images overlap the text in the first column.
    Win98
    PII 400
Subject: Re: Images overlap insert menu
Date: 7 Sep 2001 20:03:05
Message: <3b996039@news.povray.org>
Bill DeWitt <bde### [at] cflrrcom> wrote:
:     When you have enough items in an insert menu for it to make a new
: column, the images overlap the text in the first column.
  So? I think the location of the image is completely intentional.
Date: 7 Sep 2001 22:17:35
Message: <3B9980A5.630EBD4C@pacbell.net>
You can get around this by placing the mouse cursor where you want the
image to appear and use the arrow keys to navigate the insert menu.
The image will appear centered above wherever the mouse pointer is
located on the screen. Other than that I don't think the current
behavior will be changed. There were several technical difficulties
getting the feature to work at all.
Ken Tyler
Date: 8 Sep 2001 09:05:56
Message: <3b9a17b4$1@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3B9980A5.630EBD4C@pacbell.net...
    That's kind of a drag. I will get around it by making more sub-menus.
