POV-Ray : Newsgroups : povray.beta-test : Beta 34 startup today - 'Unknown error code' Server Time
16 Jul 2026 11:16:27 EDT (-0400)
  Beta 34 startup today - 'Unknown error code' (Message 1 to 10 of 11)
Subject: Beta 34 startup today - 'Unknown error code'
Date: 1 Jan 2010 08:45:40
Message: <20100101104540.38718b50.john@johncoppens.com>
Hello people.
Wanted to redo a file from a few days ago, and I get:
$ povray1 +Iglass.pov
povray: this pre-release version of POV-Ray for Unix expires in 6 day(s)
and 8 hour(s)
povray: cannot open the system configuration
file /usr/local/etc/povray/3.7/povray.conf: No such file or directory
Unknown error code
This is beta34, started up with the numeric code. Is there a cross-over
problem with the year?
John
Subject: Re: Beta 34 startup today - 'Unknown error code'
Date: 1 Jan 2010 12:40:01
Message: <web.4b3e3253a581b0ac380f8080@news.povray.org>
John Coppens <joh### [at] johncoppenscom> wrote:
> Hello people.
> and 8 hour(s)
> Unknown error code
> John
Hi John,
I have similar problem with beta 34 on Linux - Slackware 12.2 x86.
povray +FT -D +Q9 +A st546.pov
povray: this pre-release version of POV-Ray for Unix expires in 6 day(s) and 4
hour(s)
povray: /home/dad/.povray/3.7/povray.conf: 57: the user setting 'allowed' for
[Shellout Security] is less restrictive than the system 'forbidden' setting in
'/usr/local/etc/povray/3.7/povray.conf': using system setting
Unknown error code
Hope a guru can provide a fix.
Cheers,
Peter
Date: 1 Jan 2010 13:40:00
Message: <web.4b3e4125a581b0ac380f8080@news.povray.org>
> > Hello people.
> > and 8 hour(s)
> > Unknown error code
> > John
> Hi John,
> hour(s)
> Unknown error code
> Cheers,
> Peter
Hi - I've found the fix. Seems there was a similar problem in Jan 2009.
In vfe/vfe.cpp line 772.
Change 1262296800 (1 Jan 2010) to something like 2262296800 (9 Sep 2041)
And recompile...
Cheers,
Peter
Date: 1 Jan 2010 18:11:21
Message: <20100101201121.2638347c.john@johncoppens.com>
On Fri,  1 Jan 2010 13:38:29 EST
> And recompile...
> Cheers,
> Peter
Thanks Peter.
I just threw out those 3 lines (same as in a patch I found for Debian)...
John
Date: 1 Jan 2010 22:27:29
Message: <4b3ebd21@news.povray.org>
Patch for Debian? Do you mean 3.7 is packaged for Debian?
Subject: Re: Debian packaging POV 3.7 (was: Beta 34 startup today - 'Unknown error code')
Date: 1 Jan 2010 22:35:36
Message: <4b3ebf08@news.povray.org>
It is:
http://packages.debian.org/experimental/povray
And indeed it gets patched to remove the expiration.
Doesn't this violate the POV-Ray beta restrictions in every possible way?
I'll consult debian-legal, but I'd like an "opinion" from the POV-Team
first.
Date: 1 Jan 2010 23:52:02
Message: <20100102015200.544fefcc.john@johncoppens.com>
On Sat, 02 Jan 2010 00:35:36 -0300
> way? I'll consult debian-legal, but I'd like an "opinion" from the
> POV-Team first.
If I'm not mistaken, the expiration is still there. Only the explicit
year 2010 has been removed. The patch set does 4 things, the only one
related removes that limit, so you can go past 1/1/2010 by using the
betacode.
John
Date: 2 Jan 2010 15:14:34
Message: <4b3fa92a$1@news.povray.org>
>>> Debian)...
> It is:
> first.
I have now reported it to debian-legal and to the Debian bugtracker:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=563344
Date: 4 Jan 2010 17:36:38
Message: <4b426d76$1@news.povray.org>
>>>> Debian)...
>> It is:
>> first.
If they follow the source modification instructions on the source download
page then I'd probably be OK with it.
-- Chris
Date: 4 Jan 2010 22:21:25
Message: <4b42b035@news.povray.org>
>>> It is:
>>> POV-Team first.
I'm sure you'll have to be more specific/formal for it to matter; pretend
you're talking to a lawyer :)
What source modification instructions on what page? That modifications have
to be dual-licensed with GPL3? That's the only relevant "instruction" I
found on the webpages.
OK with what? With them redistributing POV betas? OK with distributing
source code too? OK with disabling the hard-limit on beta expiration?
