POV-Ray : Newsgroups : povray.beta-test : bug with #declare order Server Time
11 Apr 2026 14:40:58 EDT (-0400)
  bug with #declare order (Message 1 to 10 of 22)
Subject: bug with #declare order
Date: 26 Oct 2001 05:44:58
Message: <1nbitto64ipgqujonpn6m6r7097rsol9ec@4ax.com>
platform: POV35b6 on PII233 128 MB with NT4 SP6
I hope it is not a limitation like #if inside #if
two-line script
  #declare A#declare A=0;=1;
  #warning str(A,0,0)
prints 1 and I expected it
but script
  #declare A=#declare A=0;1;
  #warning str(A,0,0)
prints 0 but I expected 1
but what is most strange when I joined both
  #warning str(A,0,0)
  #warning str(A,0,0)
it twice prints 1
but when I changed it to (replaced second A with B)
  #warning str(A,0,0)
  #declare B=#declare B=0;1;
  #warning str(B,0,0)
it prints 0 and 1
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Subject: Re: bug with #declare order
Date: 26 Oct 2001 06:20:39
Message: <3bd938f7@news.povray.org>
> two-line script
>   #warning str(A,0,0)
> but script
>   #warning str(A,0,0)
>   #warning str(A,0,0)
>   #warning str(A,0,0)
> it twice prints 1
>   #warning str(A,0,0)
>   #warning str(B,0,0)
> it prints 0 and 1
While I agree that the behavior is confusing, for versions up to and
including 3.5 and any 3.x version or bug fix release that may follow, assume
the behavior of nesting directives inside other directives is not specified.
So the answer is: Don't use it (also the parser allows it) because the
behavior is unlikely to be made consistent before a rewrite of POV-Ray.
    Thorsten
e-mail: tho### [at] trfde
Date: 26 Oct 2001 06:46:30
Message: <dueitto7imgspv5ojmn81htn9pvbof35v0@4ax.com>
On Fri, 26 Oct 2001 12:20:37 +0200, "Thorsten Froehlich"
While I can get such answer, shouldn't be such sentence builded into
documentation instead of "directives can appear in almost any place in
the scene file - even in the middle of some other statements". You
wrote "the behavior of nesting directives inside other directives is
not specified". What about #macro inside #macro? #switch inside
#switch? Or mixing: #local inside #macro? This subject should be IMO
described little more within documentation.
ABX
Date: 26 Oct 2001 07:59:48
Message: <0qjittsg3bmv8422pj5egqvo8p4sg9p36h@4ax.com>
Is this the same thing ?
#local A=array#local C=1;#while(C<=5)[C]#local C=C+1;#end
personally I prefer post such things to warn people it not work
ABX
Date: 26 Oct 2001 09:07:08
Message: <3bd95ffc@news.povray.org>
You misunderstood what I mean with nesting.  Think about it and it should be
obvious what is meant with nesting based on your examples.
    Thorsten
Date: 26 Oct 2001 09:09:16
Message: <3bd9607c@news.povray.org>
I would not recommend the above as it isn't disallowed.  Use a macro and
call it, that will always work as you expect.
    Thorsten
Date: 26 Oct 2001 09:19:01
Message: <icoittcv9sfj456mtla771o8csgf1gp6eg@4ax.com>
On Fri, 26 Oct 2001 15:07:05 +0200, "Thorsten Froehlich"
Perhaps.
I just want to say it's good idea to add not working statements to
documentation and write something about this problem.
ABX
Date: 26 Oct 2001 09:21:36
Message: <lloittsoa1lusa6n1of9epl8or51rt8s6e@4ax.com>
On Fri, 26 Oct 2001 15:09:14 +0200, "Thorsten Froehlich"
like this ?
#macro B() array#local C=1;#while(C<=5)[C]#local C=C+1;#end #end
#local A=B()
it still not work with beta 6
ABX
Date: 26 Oct 2001 09:28:48
Message: <l5pittsu5l5peakv2dda70nu1n88s6m04h@4ax.com>
> #local A=B()
but this works fine
#local A=array[#local C=1;#while(C<=4)C][#local C=C+1;#end 5]
ABX
Date: 26 Oct 2001 09:37:07
Message: <1npittopq343jbkgtlm1vthlg7uhffe6b8@4ax.com>
> #local A=B()
it is probably connected with next thread
ABX
