POV-Ray : Newsgroups : povray.beta-test : crash when stopping in the first line Server Time
13 Oct 2025 19:05:45 EDT (-0400)
  crash when stopping in the first line (Message 1 to 10 of 11)
Subject: crash when stopping in the first line
Date: 10 Oct 2001 14:08:09
Message: <1103_1002737295@iq>
w2k - Athlon1.3GHz - 384MB - Pov3.5B6
I have just tested this with one scene yet, but it is replicable...
The scene contains some timeconsuming stuff (media)
I render it in 512x384 AA0.2
if I press the stop-button before the first rendered line is displayed, than it
crashes (pvengine.exe created an error, windows creates an error-report and POV gets
closed)
I will see, if I can provide more information ...
Subject: Re: crash when stopping in the first line
Date: 10 Oct 2001 15:01:32
Message: <3bc49b0c$1@news.povray.org>
I have seen the same error a few times. I wasn't quite sure when it was when
it happened, but it did always seem to be when it was just starting off and
I stopped it. It was also a problem when stopping the render during
radiosity pre-trace.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"jan Walzer" <iq### [at] walliqde> wrote in message news:1103_1002737295@iq...
than it crashes (pvengine.exe created an error, windows creates an
error-report and POV gets closed)
Date: 10 Oct 2001 15:20:23
Message: <3bc49f77$1@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bc49b0c$1@news.povray.org...
when
and
The pretrace stop still crashes with the beta.6.icl.win32
I can also get it to crash if I stop and restart a render too quickly and I
guess it does happen at the first line, or at least when the render window
begins to display something.
Bob H.
Date: 10 Oct 2001 15:25:46
Message: <3bc4a0ba@news.povray.org>
I've been seeing this error as well, but hadn't been able to figure out just
what was actually needed to replicate it.
-autowitch
http://www.autowitch.org
when
and
> - Slime
Date: 10 Oct 2001 22:25:02
Message: <3BC502C3.6090200@videotron.ca>
Some further tests done by Tony[B] and yours truly have revealed that it
And does not happen at all when using Windows 98.
> -autowitch
> when
> and
>>- Slime
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 10 Oct 2001 22:40:21
Message: <3bc50695$1@news.povray.org>
I have Win 98 and have been getting it, with BMPs I believe. I'm not sure
it's consistent, though.
- Slime
"Francois Labreque" <fla### [at] videotronca> wrote in message
news:3BC### [at] videotronca...
just
> > -autowitch
> > when
> > and
> >>- Slime
> /*Francois Labreque*/#local a=x+y;#local b=x+a;#local c=a+b;#macro P(F//
> /*    flabreque    */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
> /*        @        */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
Date: 10 Oct 2001 22:42:33
Message: <3bc50719@news.povray.org>
Well, it sure is for me. If I stop renders with radiosity, before the
mosaicing is done, and when using PNG output, it crashes. There are two
lines that say "Problem with... [something]", but the window dissapears
before I can finish reading them.
Date: 11 Oct 2001 02:21:10
Message: <Mh3YFIAeCTx7Ewu2@econym.demon.co.uk>
This is the same thing that was initially reported in beta 4
   http://news.povray.org/3bb4605d$1@news.povray.org
With my W98se and beta 6 it still happens under the same conditions,
namely
 When the output format is PNG
 And the render is stopped during radiosity pre-trace or while rendering
 lines 0 to 2.
The size and speed of the image doesn't matter. If stopped before line 3
it always crashes. If stopped on or after line 3 it doesn't.
Mike Williams
Gentleman of Leisure
Date: 17 Oct 2001 11:28:34
Message: <3bcda3a2@news.povray.org>
I presume you were using PNG output ?
There was a problem in this case with PNG output, which has now been fixed.
-- Chris
Date: 25 Oct 2001 01:24:02
Message: <3bd7a1f2@news.povray.org>
Sorry, not true.  I get stack fault/gpf whenever rendering is stopped prior
to the first line being drawn, usually due to a protracted parse.
Duron 800MHz, 256 MB, Win98SE, Pov-Ray 3.5b6
"Chris Cason" <newsadmin-despam-@povray-no-spam.org> wrote in message
news:3bcda3a2@news.povray.org...
fixed.
> -- Chris
