POV-Ray : Newsgroups : povray.beta-test : "warp" broken in beta 4? Server Time
13 Oct 2025 21:30:24 EDT (-0400)
  "warp" broken in beta 4? (Message 1 to 9 of 9)
Subject: "warp" broken in beta 4?
Date: 1 Oct 2001 16:06:17
Message: <1103_1001966819@mcmurdo>
I have a scene, originally written for MegaPOV 0.5, which takes a complex texture used
on a flat part of a model, and imposes a cylindrical warp for use on another part.
It fails under 3.5 beta 4.  Here's an extremely simplified version:
#declare T_Flat  = texture { pigment { gradient x }}
#declare T_Cylindrical = texture { T_Flat
  scale <0.075/pi,1,10>
  warp { cylindrical }
  rotate x*-90
Is that use of "warp" not permitted under 3.5, or is it supposed to work like it did
in MegaPOV?
Subject: Re: "warp" broken in beta 4?
Date: 1 Oct 2001 16:40:32
Message: <3BB8D574.8F7F5F74@gmx.de>
in MegaPOV?
It works AFAIK.
See the 'object_pattern.pov' demo scene for example.
Can't say anything about differences to megapov right now.
Date: 1 Oct 2001 16:52:23
Message: <1103_1001969579@mcmurdo>
On Mon, 01 Oct 2001 22:43:32 +0200, Christoph Hormann <chr### [at] gmxde> wrote:
did in MegaPOV?
> It works AFAIK.
Not for me.  I try to render, and I get:
     File: f:\users\jeff\povray\scenes\warperr.pov  Line: 3
       warp <----ERROR
     Parse Error: No matching } in 'texture', warp found instead
     Returned from renderer with error status
Date: 1 Oct 2001 17:04:25
Message: <3BB8DB16.9B16007F@gmx.de>
>        warp <----ERROR
Hmm, it seems to be a bug, i'm just not sure in which situations exactly
this happens.
Date: 1 Oct 2001 17:10:35
Message: <3bb8dbcb@news.povray.org>
In article <1103_1001966819@mcmurdo> , Jeff Lee <godfrey@shipbrook.com>
>   rotate x*-90
I can confirm this does not work.  However, i do not know if it is supposed
to work in 3.5 or not.
    Thorsten
Date: 1 Oct 2001 18:21:10
Message: <3BB8ED0F.D50F6F7C@gmx.de>
See the 'object_pattern.pov' sample scene for a working example.
It seem to work with texture maps but not if they are declared.
Date: 1 Oct 2001 20:20:03
Message: <3BB907B7.4080309@videotron.ca>
It is not specific to declared textures as it fails on the following as
well:
sphere{
     < 0, 0, 0 > 2
     texture{
         pigment{ gradient x }
         rotate x*-90
 From my experience, it works when it is inside a pigment, finish or
normal block, but not at the "texture" level.
For example, Jeff's code will work, if modified this way:
#declare P_Flat  = pigment { gradient x }
     pigment{
         P_Flat
     rotate x*-90
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 1 Oct 2001 23:41:17
Message: <3bb93711.8286435@news.povray.org>
>      pigment{
>          P_Flat
>      rotate x*-90
Unfortunately, my *original* texture was much more complex, with several
levels of textures.  :-(
Date: 2 Oct 2001 05:17:03
Message: <3bb9860f@news.povray.org>
Francois Labreque schrieb in Nachricht <3BB### [at] videotronca>...
I guessed something like that, too, but the mentioned object_pattern.pov
uses the war at the texture level and it works.
#declare Tex_Column=
  object {
    Text_Obj
    texture { Tex_1 },
    texture { Tex_Metal_A }
Strange,
Marc-Hendrik
