POV-Ray : Newsgroups : povray.beta-test.binaries : extended insert menu - november bonus pack (zip - 321 kbu) Server Time
19 May 2024 09:00:25 EDT (-0400)
  extended insert menu - november bonus pack (zip - 321 kbu) (Message 1 to 3 of 3)
Subject: extended insert menu - november bonus pack (zip - 321 kbu)
Date: 23 Nov 2001 12:34:58
Message: <bo1tvto7s6llf4v0bnvmb48n1ncf9s267n@4ax.com>
Here is extended insert menu with almost all names from standard include files
categorized by type. I prefer to upload this here becouse as base POV it will
change follow next betas. I plan to add some bitmaps to this (textures, colors,
shapes). Any typing erros? Any comments? Any suggestions for further
categorization?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Download 'bonus.zip' (322 KB)
Subject: Re: extended insert menu - november bonus pack (zip - 321 kbu)
Date: 23 Nov 2001 15:09:46
Message: <3BFEAD09.61A516DB@gmx.de>
> categorization?
Wow, did you do this completely by hand or do you have some automatism?
If yes, this could be very useful for custom include files.
Only one inconsistency i recognized until now: The functions
'f_hetero_mf', 'f_ridged_mf' and 'f_ridge' should probably go to 'noise
functions'.
Date: 26 Nov 2001 03:51:17
Message: <41040uo11b9pibnmbn3ll259h8r15o7lc9@4ax.com>
On Fri, 23 Nov 2001 21:09:45 +0100, Christoph Hormann <chr### [at] gmxde>
Both. I've made lists by hand for povray script. Then runed script to create
files. And finally renumbered some files with 'Multi-raname tool' from Windows
Commander.
I plan to add bitmaps to it for color_maps, pigments, textures and shapes.
Here is example of script used to make it.
  #local Names=array[5]{
    "T_Brass_1A"
    "T_Brass_1B"
    "T_Brass_1C"
    "T_Brass_1D"
    "T_Brass_1E"
  #local Counter=0;
  #while ( Counter<dimension_size(Names,1))
    #fopen File concat(
      "c:\\Program Files\\POV-Ray for Windows v3.5\\",
      "Insert Menu\\21 - Include files - keywords\\",
      "90 - 'metals.inc'",
      "30 - metals textures"
      "\\",Names[Counter],".txt"
    ) write
    #write(File,Names[Counter])
    #fclose File
    #local Counter=Counter+1;
> functions'.
I will change it and upload updated version after new beta  (I hope with some
bitmaps). Thanks.
ABX
