POV-Ray : Newsgroups : povray.beta-test.binaries : Function / pattern issues. New inbuilt f_elliptical_sphrswp(). Server Time
16 Jun 2024 23:12:35 EDT (-0400)
  Function / pattern issues. New inbuilt f_elliptical_sphrswp(). (Message 1 to 5 of 5)
Subject: Function / pattern issues. New inbuilt f_elliptical_sphrswp().
Date: 13 Jun 2020 15:32:09
Message: <5ee529b9$1@news.povray.org>
<---------------------- References. Twelve previous posts
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ee4b9e3%40news.povray.org%3E/
and
http://news.povray.org/povray.beta-test.binaries/thread/%3C5ee4dc4b%241%40news.povray.org%3E/
To povr adding new f_elliptical_sphrswp(). As Cousin_Ricky has
mentioned, it is not a match for an elliptical torus (supertoroid 1,1
asymmetric a,b), but probably something useful. See attached images.
Of note the implementation is testing out a torus pre-filter - my f_dual
idea to improve isosurface performance. Idea works for performance, but
it introduces a gradient change away from the surface so there are
always max gradient warnings. The actual gradient to use is always
around 1.0 for the sweep itself. So, need to figure out smarter max
gradient determination (near roots); Create a warning on/off option for
isosurfaces(1) - or do both.
(2) - IIRC. Megapov had a warning on/off thingy.
#declare angleStart = 153;
#declare angleArc   = -137;
#declare Iso98 = isosurface {
     function {
         f_elliptical_sphrswp(x,y,z,ax,bz,r,angleStart,angleArc,0)
#declare Pig00 = pigment {
     function {
         f_elliptical_sphrswp(x,y,z,ax,bz,r,angleStart,angleArc,1)
Parameters: x, y, z
Six extra parameter required:
1. The traditional a multiplier of the x axis.
2. The traditional b multiplier of the z axis.
3. The minor radius, r.
4. The starting angle. 0 to 360.
5. The arc angle from the start angle. -360 to 360.
6. 0 = sweep with optimization. 1 = return 0 to 1 map value matched to
angular rotation of arc.  2 = skip up front in torus filter. (e.g. Using
sweep values for map control)
Notes. Like the f_torus() function the f_elliptical_sphrswp() sits
around the y axis at the origin.  In other words, it is sitting in the
x,z plane.  Angles and directional angles are left handed about y.
With respect to isosurfaces; Gradients are decent, but due the internal
method of calculation, performance is somewhat volatile. Larger r values
tend to run more slowly. Rays more orthogonal to the y axis are slower -
sometimes slower than a parametric representation.
The function is close to that of an elliptical torus - supertoroid with
e1,e2 at 1.0 (spherical) and asymmetric x,z axis values.  Also this
method has start and end points - arcs - there is less continuity /
smoothness at the cap spheres than elsewhere in each arc.
Bill P.
Download 'storyellipsphswp.jpg' (63 KB) Download 'storysupertoroidtoesweep.jpg' (35 KB)
Preview of image 'storyellipsphswp.jpg'
Preview of image 'storysupertoroidtoesweep.jpg'
Subject: Re: Function / pattern issues. New inbuilt f_elliptical_sphrswp().
Date: 14 Jun 2020 12:29:30
Message: <5ee6506a$1@news.povray.org>
> and
> Bill P.
Assuming a threshold of zero, using min(f_elliptical_sphrswp() , 1)
should clamp out the areas of high gradient.
If the threshold is, or need to be, around 1, use something like 1.5 to
2 as the clamping value.
May be worth a try.
Date: 15 Jun 2020 07:07:28
Message: <5ee75670$1@news.povray.org>
That sort of clamping does sometimes work.
Here, what's happening is I'm using two functions with good/low
gradients. The container function is cheap to compute - a scaled torus.
The sweep is expensive to compute. If either is run alone there are no
gradient warnings - and there's a switch to turn off the torus
pre-filter so folks can, for example, use the sweep function with
pigment maps or whatever.
The problem comes on the switch from the larger containing function to
the elliptical sweep function. It's there that we 'generate' the larger
gradient values. To the overall functionality & result those
discontinuities don't matter.
The gradients are not matched/aligned during the switch and how much
misaligned isn't constant. Blending the functions would fix the gradient
warnings, but then I lose the performance benefit. So, at least at the
moment, I think I'm stuck needing to change how the gradient warnings
are reported or how generated.
Aside: As you and Bald Eagle suggested, it's now on my near term list to
try and implement 3d vector<->double encode and decode functions. I'm
thinking each encoded vector value at 21 bits and 1 bit, combined
exponent switching from a +-1.0 range to a +-10 range at 5 or 6 digits
of accuracy.
In working on the elliptical sphere sweep function, I got to thinking a
+-10 range at 5-6 digits is plenty of both range and accuracy in many
situations. With spline control points, for example. We'll see.
Bill P.
Date: 15 Jun 2020 11:44:46
Message: <5ee7976e$1@news.povray.org>
>> to 2 as the clamping value.
> of accuracy.
> Bill P.
I see, huge gradient similar to what we can expect when using the
gradient or radial patterns in an isosurface.
Date: 16 Jun 2020 07:39:02
Message: <5ee8af56$1@news.povray.org>
Yes, suppose similar if using POV-Ray gradient, radial and seeing the
clamp. Povr if the normal 0-1 fmod-ish clamping is on, and your
isosurface is catching the fmod clamping so to speak(1).
Where off in povr the gradient pattern's 'gradient', for example, is
good/linear.
Bill P.
(1) And not using a wave modifier like triangle... It depends. General,
simple statements/rules are hard to come by with isosurfaces. With our
current solver low gradients being key for good performance is one.
Gradient warnings have always been iffy, though often enough helpful.
Change a set of rays approach to an isosurface and the gradients are
often different. Tighter bounding helps for both the usual ray misses /
hits the bounding box reasons - and that smaller dimension(s) along the
ray help with the 'effective' gradients.
