POV-Ray : Newsgroups : povray.beta-test.binaries : optics.pov 3.7.0 vs 3.7.1 Server Time
16 Jun 2024 20:32:12 EDT (-0400)
  optics.pov 3.7.0 vs 3.7.1 (Message 1 to 10 of 60)
Subject: optics.pov 3.7.0 vs 3.7.1
Date: 24 Feb 2016 08:23:49
Message: <56cdaee5@news.povray.org>
optics.pov from scenes/advanced...
The appended files had been rendered using povray V3.7.0 and Version
3.7.1-alpha.8492620.unofficial.
Could someone please check this?
Thorsten aka ThH
Download 'optics_3.7.0.png' (138 KB) Download 'optics_3.7.1.png' (137 KB)
Preview of image 'optics_3.7.0.png'
Preview of image 'optics_3.7.1.png'
Subject: Re: optics.pov 3.7.0 vs 3.7.1
Date: 24 Feb 2016 08:45:08
Message: <56cdb3e4$1@news.povray.org>
Am 24.02.2016 um 14:24 schrieb ThH:
> Thorsten aka ThH
Ooops... System is AMD64 with Debian. Excuse.
Date: 24 Feb 2016 08:53:42
Message: <56cdb5e6$1@news.povray.org>
Am 24.02.2016 um 14:46 schrieb ThH:
>> Thorsten aka ThH
Can't reproduce the issue with the Windows version.
Are you sure you have a clean build?
Date: 24 Feb 2016 09:27:24
Message: <56cdbdcc$1@news.povray.org>
Am 24.02.2016 um 14:53 schrieb clipka:
The source is from github and hasn't been modified.
Povray has been build using:
cd ~/Downloads/povray-master/unix/
./prebuild.sh
cd ..
./configure --prefix=/home/thh/POV_Master COMPILED_BY="ThH
<no.spam@address>" LIBS="-lboost_system -lboost_thread"
make check install
No extra configure options.
 From my point of view I'd say it's clean.
I could provide the output of the build process...
Date: 24 Feb 2016 09:55:30
Message: <56cdc462@news.povray.org>
   Happens here too on 3.7.1-alpha.8454683, AMD FM-6300, Ubuntu 14.04.3 LTS.
jaime
Date: 24 Feb 2016 10:01:58
Message: <56cdc5e6@news.povray.org>
Am 24.02.2016 um 15:55 schrieb Jaime Vives Piqueres:
> LTS.
> jaime
Thanks for checking and confirming Jaime :)
So it's not just me ;)
Date: 24 Feb 2016 10:51:23
Message: <56cdd17b$1@news.povray.org>
Am 24.02.2016 um 16:02 schrieb ThH:
>> LTS.
>> jaime
Okay, here's the deal: I can't reproduce it, so my only chance to
identify the root cause is to have a close look at the code, but for
that to make any sense I need a clear picture of exactly where to look.
To this end, I need you (that's "you" as in "y'all") to:
- figure out the simplest possible scene that exhibits the problem;
- identify exactly which commit (in the master branch) broke the scene; and
- do plenty of systematic toying around with the scene to figure out the
exact circumstances under which the error shows. (For instance, why
isn't the green beam affected? Is it because it is not reflected? Then
why aren't the red and blue beams affected right after the first
reflection? Does max_trace_level have anything to do with it? Why does
only the bottom of the red sub-beams seem affected? Why the top and
center of the blue sub-beams? etc. -- Be inquisitive and creative!)
Date: 24 Feb 2016 11:03:52
Message: <56cdd468@news.povray.org>
Am 24.02.2016 um 16:51 schrieb clipka:
I'm in :)
Date: 24 Feb 2016 12:11:05
Message: <56cde429@news.povray.org>
.3
>>> LTS.
>>> jaime
 and
e
The problem might not be only in the code, I tested several heads and
compilers
| head \ compiler | gnu | clang | intel | gnu with debug |
| 3.7.0 stable    |  ok |  ok   |  ok   |  ok            |
| 3.7.1 master    | BUG |  ok   |  ok   |  BUG           |
| my master (hg)  | BUG |  ok   |  ok   |  BUG           |
| hgpovray        | ok  |  ok   |  ok   |  ok            |
notice, the intensity of green on stable branch seems higher (might be
known... gamma ?)
the difference between hgpovray and my master is:
* hgpovray is late on the refactoring of the code
* I have all my additions in hgpovray
the difference between my master and official master:
* I'm about a year late on synchronisation with refactoring
last pull from master to my master was April-June 2015, so the "bug" was
already there then.
The start/fork of hgpovray is 8 june 2014, so code before that date was
still fine.
The OP's picture was in white bug, mine is yellow.
(Ubuntu 64 bits 15.10)
Just one year of patches to check... it might be tied to the size of a
structure, and a particularity of Gnu compiler (gcc/g++ 5.2.1 20151010)
sensible to that... or a change of initialisation...
Download 'gmpovray.png' (239 KB)
Preview of image 'gmpovray.png'
Date: 24 Feb 2016 12:31:46
Message: <56cde902@news.povray.org>
Am 24.02.2016 um 17:04 schrieb ThH:
> I'm in :)
Find attached optics_mod.pov.
Hope it's a good starter on the the way for a minimal scene to produce
the error.
In addition I've attached 2 pics rendered on my machine. Again 3.7.0 vs
3.7.1.
Now for some more investigation... ;)
Download 'optics_mod.pov.txt' (2 KB) Download 'optics_mod_3.7.0.png' (84 KB) Download 'optics_mod_3.7.1.png' (91 KB)
Preview of image 'optics_mod_3.7.0.png'
Preview of image 'optics_mod_3.7.1.png'
