POV-Ray : Newsgroups : povray.beta-test.binaries : HDR image reversed when read Server Time
27 Mar 2026 05:32:15 EDT (-0400)
  HDR image reversed when read (Message 1 to 5 of 5)
Subject: HDR image reversed when read
Date: 6 Feb 2006 22:50:38
Message: <43e8190e@news.povray.org>
Windows XP Pro - 2.4GHz - 1.0GB RAM - beta11
As can be seen in the attached images, HDR format images seem to be reversed
when read.   The scene displays simply a box with an image map and is
identical for both except on uses a BMP format image and the other uses a
HDR format image, both made from the same original JPG file. This is valid
for "map_type 0", I haven't tested for others.
SCENE FILE:
//start
#declare Map="megane.hdr"; //HDR
//#declare Map="megane.bmp"; //BMP
camera{orthographic
  up y*2.05*image_height/image_width
  right x*2.05
  location <0,-0.15,-2>
  look_at  <0,-0.15,0>
box{<0,0,0><1,1,1> pigment {image_map {hdr Map once interpolate 2 map_type
0}} finish {ambient 1 diffuse 0} scale <2,1,1> translate <-1,-.5,0.1> }
//HDR
//box{<0,0,0><1,1,1> pigment {image_map {hdr Map once interpolate 2 map_type
//BMP
//end
-tgq
Download 'BetatestHDR-37.jpg' (123 KB) Download 'BetatestBMP-37.jpg' (122 KB)
Preview of image 'BetatestHDR-37.jpg'
Preview of image 'BetatestBMP-37.jpg'
Subject: Re: HDR image reversed when read
Date: 7 Feb 2006 03:55:03
Message: <ds9n2p$isn$1@chho.imagico.de>
The radiance HDR format supports different orientations of the image but
the reader in POV-Ray treats all the same way currently (just like most
other HDR readers around).  So you should make sure the program you use
to write the HDR files uses normal (top to bottom, left to right)
orientation.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 7 Feb 2006 07:10:46
Message: <43e88e46$1@news.povray.org>
> other HDR readers around).  So you should make sure the program you use to
> orientation.
> Christoph
Opens forwards in HDRShop which I would think is a common HDR program.  It
also opens forwards in megapov.
-tgq
Date: 7 Feb 2006 09:40:01
Message: <web.43e8b07ed04d4fba6c4803960@news.povray.org>
> > orientation.
> > Christoph
> -tgq
As a follow up, I tried writing and reading HDR images successively in the
beta.  (i.e., write the HDR, then read the HDR output by POV as an image
map and rewrite, etc.).  This had the effect of flipping the image back and
forth.  It would appear to me that the output is being written correctly,
but that it is being read backwards.  The attached image shows three
successive outputs from this method (converted to jpg by HDRShop)
As a side note, I also noticed that I get "Unrecognized output file format
H" after the render even though the render and image creation was
successful.
SCENE FILE:
//start
camera{orthographic
  up y*2*image_height/image_width
  right x*2
  location <0,0,-2>
  look_at  <0,0,0>
#declare Map="beta1.hdr"; //HDR - name of HDR output by POV
box{<0,0,0><1,1,1>
  pigment {image_map {hdr Map once interpolate 2 map_type 0}}
  translate <-0.5,-0.5,0.1>
  scale <2,2*image_height/image_width,1>
//end
-tgq
Download 'beta.jpg' (86 KB)
Preview of image 'beta.jpg'
Date: 7 Feb 2006 12:35:03
Message: <dsalng$rnj$1@chho.imagico.de>
Yes, indeed it seems the current reading code mirrors the image.
