POV-Ray : Newsgroups : povray.beta-test.binaries : Bug with continue and/or radiosity Server Time
1 Jul 2024 04:57:34 EDT (-0400)
  Bug with continue and/or radiosity (Message 1 to 6 of 6)
Subject: Bug with continue and/or radiosity
Date: 12 Sep 2001 12:28:56
Message: <3b9f8d48@news.povray.org>
I have included two images and the source code.  The first image is the
actual output, the second I used green circles to highlight the areas I am
referring to.  This image was created by simply allowing the render to get
about 10 percent complete then stopping and then (using the +c switch)
continuing the render.  I stopped and continued the render several times.
As you can see the coloration of the image changed each time I did a
continue even though no code was changed.  The background, metal box and the
wood box were all changed.  This also happens within Megapov 0.7.  ( I
haven't tested with any other versions.)
Download 'MetalTest1.jpg' (20 KB) Download 'MetalTest2.jpg' (23 KB) Download 'MetalTest.zip' (1 KB)
Preview of image 'MetalTest1.jpg'
Preview of image 'MetalTest2.jpg'
Subject: Re: Bug with continue and/or radiosity
Date: 12 Sep 2001 12:46:40
Message: <3b9f9170$1@news.povray.org>
Appears to be radiosity.  Continue works as intended.
Without the radioisty the image can be continued without alteration, with
radiosity it changes each time.
"Patrick Dugan" <pat### [at] usnetcomcorpcom> wrote in message
news:3b9f8d48@news.povray.org...
the
Date: 12 Sep 2001 23:14:23
Message: <3BA02588.6F66A9D5@pacbell.net>
This is known limitation with radiosity and has been the same way since
radiosity was first introduced. Mega-Pov had an option to save the
radiosity data from the first pass into a file which could be re-used
during a continued render to solve the problem. I don't recall if this
made it into v3.5 as an option or not. You might try checking the docs
in the radiosity section.
Ken Tyler
Date: 12 Sep 2001 23:55:15
Message: <3BA02F1D.C1F37C10@pacbell.net>
Ken wrote:
> I don't recall if this made it into v3.5 as an option or not. You might
> try checking the docs in the radiosity section.
Yes it has been included in v3.5. Unfortunately the Docs fors radiosity have
not be finished yet and you will have to figure out how to use this on the
scant evidence presented.
Ken Tyler
Date: 13 Sep 2001 01:44:32
Message: <3ba047c0@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote ...
have
Check the MegaPov docs - they explain how to use loadfile and savefile (I
think those are the keywords).
-Nathan
Date: 13 Sep 2001 08:31:05
Message: <3ba0a709$1@news.povray.org>
Thanks! I appreciate the help!
"Nathan Kopp" <nat### [at] koppcom> wrote in message
news:3ba047c0@news.povray.org...
might
> have
the
> -Nathan
