POV-Ray : Newsgroups : povray.animations : <no subject> Server Time
15 May 2024 15:31:12 EDT (-0400)
  <no subject> (Message 1 to 3 of 3)
Subject: <no subject>
Date: 8 May 2017 08:10:01
Message: <web.59105ff5c23a6d96ad0770d0@news.povray.org>
-Does POV-Ray support animation rendering?
-Does POV-Ray support keyframe, timeline (interpolation) animation rendering
from Blender 3D models?
-Does POV-Ray include equivalent support for Marked Freestyle Line Edges in
Blender 3D?
-If POV-Ray does support those previous from Blender3D, does it support command
line, background animation rendering?
-Given that I can use plugin support to export my animation to different formats
from Blender 3D, what would be the ideal file format for my keyframe, 3D
animation model?
-Can I be given an example of "command line animation rendering via file"
command prompt entry?
Subject: Re: <no subject>
Date: 8 May 2017 08:55:01
Message: <59106aa5$1@news.povray.org>
Yes.
No PovRay is a renderer and the windows version comes with a text
editor. That is it. You have to do the hard work yourself. Or use the
PovRay exporter that comes with Blender.
> Blender 3D?
No, PovRay uses mathematical primitives. It can handle meshes and
heightfields But not like Blender.
I can say yes to that. :)
> animation model?
To use PovRay. You need to export and render each frame separately. You
can use Blender to do this.
  scene
I don't do that thing, myself. So I can't help there.
There should be examples in the Help and Tutorial files.
Regards
Date: 8 May 2017 12:05:20
Message: <59109740$1@news.povray.org>
A set of demo animations is shipped with POV-Ray and can be found in the
directory <install_location>/scenes/animations. You can find the current
master development versions on line at:
https://github.com/POV-Ray/povray/tree/master/distribution/scenes/animations
If you were in a local directory with copies of the splinefollow
directory files you could render the animation frames with the commands:
povray splinefollow.pov +kf0.1666 +kff20 +kc declare=fp=0
or
povray splinefollow.ini
Bill P.
