POV-Ray : Newsgroups : povray.animations : relativistic travel effects Server Time
20 Sep 2024 21:09:04 EDT (-0400)
  relativistic travel effects (Message 1 to 10 of 13)
Subject: relativistic travel effects
Date: 4 Nov 2016 20:50:06
Message: <web.581d2c98d977da711d2ae3900@news.povray.org>
Hi there,
i am thinking of the tools i could use to make an animation of a camera
accelerating toward 0,99c speed.
If i remember well, i would have to use a widening focal to make the direction
the camera is going appear as if it was receding and concentrating the field of
view toward a point.
For this i could use some kind of conical media, going darker at the sides and
adding redshift effects, and chromatic aberrations.
See : www.youtube.com/watch?v=JQnHTKZBTI4
Am I in the good direction, any better ideas ?
Thanks
Subject: Re: relativistic travel effects
Date: 4 Nov 2016 22:30:01
Message: <web.581d43536c13e4639c5d6c810@news.povray.org>
"rodv92" <nomail@nomail> wrote:
> Hi there,
Maybe a mesh camera? Something I'm only now trying to learn about but I know
there's effects using mesh camera macro (example scene files) for lens
distortion such as barrel and pincushion.
I recall from years ago there were things tried by people to point the POV-Ray
camera into cone shapes, that could have been for media containers, but
unfortunately I can't remember if anything was done to simulate near-light
speed. Probably was, but I didn't find anything in a search just now.
Date: 5 Nov 2016 00:40:00
Message: <web.581d61eb6c13e4639c5d6c810@news.povray.org>
> > Hi there,
Good thing you asked about this sort of thing because I finally looked at the
mesh camera files and found that the pincushion effect could possibly be what
you need. You will have to find out for yourself, but try the following from
...scenes\camera\mesh_camera\meshcam_persp_compare.pov
   meshcam_lens(image_width, image_height, 67, -2, "")
//    meshcam_pinhole(image_width, image_height, c_angle, "")
Replacing the commented line with this "lens" line, look for it at the first
#declare camera_mesh=
I think it should render a scene with no other changes made, but you'll just
have to find out.
The 67 is camera angle and the -2 is pincushion amount. Negatives for that,
positive for barrel distortion.
Date: 5 Nov 2016 04:42:15
Message: <581d9b67$1@news.povray.org>
Am 05.11.2016 um 01:49 schrieb rodv92:
> Hi there,
("This video is not available in your country.")
Oh great.
I hate YouTube.
Anyway:
From what I know you'll need more than just a distortion of the field of
view; most notably, objects will appear "rotated" somehow.
There used to be a patched version of POV-Ray specifically designed to
simulate relativistic effects. It'll be quite out of date, but maybe
it'll do what you need.
Date: 5 Nov 2016 08:35:01
Message: <web.581dd1436c13e4639c5d6c810@news.povray.org>
> > Hi there,
> Oh great.
> I hate YouTube.
I was going to see if I could find something else similar enough but instead
this other web page about physics rendered with P-R caught my attention.
Includes relativistic effects and links to more.
http://bugman123.com/Physics/index.html
The YouTube animation basically shows a series of accelerations showing a
stretching forward viewpoint and curving surroundings together with shifting
color (Redshift), also lack of color nearby.
Searched and found this web page of text+pictures about that. Was based on
POV-Ray 2.0, no luck locating the actual program. All broken links, as well as
the one from povray.org
https://www.researchgate.net/publication/2574193_Relativistic_Ray-Tracing_Simulating_the_Visual_Appearance_of_Rapidly_M
oving_Objects
Date: 5 Nov 2016 09:36:31
Message: <581de05f$1@news.povray.org>
I remember a video made with a patched version of povray from years ago.
I have never been able to find it again.
But using the wayback machine you can download the source code here
https://web.archive.org/web/19970220101552/http://www.cs.mu.oz.au/~andrbh/raytrace/raytrace_source.html
I hope it is the right one.
Regards
Date: 5 Nov 2016 09:40:04
Message: <581de134$1@news.povray.org>
This was the thread I found it in.
http://news.povray.org/povray.unofficial.patches/thread/%3Cweb.3de6ef98c20e2bf3c571aa6c0%40news.povray.org%3E/?mtop=199902
Regards
Date: 5 Nov 2016 09:50:43
Message: <581de3b3$1@news.povray.org>
Am 05.11.2016 um 14:36 schrieb Stephen:
Just 722 kByte in 46 source code files? With makefiles and all?
Wow -- if only modern POV-Ray was that lean ;)
Then again, that was over 20 years ago...
Date: 5 Nov 2016 10:00:00
Message: <web.581de5466c13e463634be200@news.povray.org>
VSauce did an episode on this, so it probably contains information which is
probably current / accurate.
https://www.youtube.com/watch?v=3pAnRKD4raY
Hope that may help.
As others have pointed out, there have been a few attempts to do this in
POV-Ray.  Very nice job digging that all up - source and everything!  :)
Date: 5 Nov 2016 10:03:26
Message: <581de6ae$1@news.povray.org>
I am sure you could do better. ÜbertreibenPov?
Regards
