POV-Ray : Newsgroups : povray.animations : **** Help Rotating An Object **** Server Time
2 Jun 2024 13:24:18 EDT (-0400)
  **** Help Rotating An Object **** (Message 1 to 3 of 3)
Subject: **** Help Rotating An Object ****
Date: 9 Nov 2007 12:15:00
Message: <web.47349529a313fa8343e9d3860@news.povray.org>
Hey all,
Well basically I have created a scene with an object (like a fan) in it, but
what I am trying to do is actually rotate the object around quite quickly so it
looks like its creating a gust of wind. All i need to know is how to do the
rotating business?? I mean....I have tried rotating it with the clock variable
in the x, or the y, or the z axis...but it just moves the head of the object
around the screen...instead of what i want (making it rotate around and around
on the spot)!
Does anyone have any ideas!?!?
Subject: Re: **** Help Rotating An Object ****
Date: 9 Nov 2007 12:21:44
Message: <47349728$1@news.povray.org>
> Hey all,
> on the spot)!
Rotations are around the origin of the scene. POV-Ray has no idea what
the "center of the object" is. You need to rotate the object before
moving it. Keep it centered at the origin, rotate it, *then* move it to
the place you want it on the scene.
Date: 30 Apr 2011 00:40:00
Message: <web.4dbb91fa84cd035bb6f0ad930@news.povray.org>
"benjy" <ben### [at] hotmailcom> wrote:
> Hey all,
> on the spot)!
> Regards,
Translate the fan to the center of the scene, rotate it there, and then
translate it back.If it's supposed to rotate on the X axis, use rotate
x*clock*10. If it's the Z axis you need to rotate it around, use rotate
z*clock*10. If it's too slow (I doubt it will be too slow, but just in case)
change 10 to 20 or 50, maybe even 100.
