POV-Ray : Newsgroups : povray.animations : Illegal scaling, that is'nt illegal... Server Time
15 May 2024 15:17:29 EDT (-0400)
  Illegal scaling, that is'nt illegal... (Message 1 to 7 of 7)
Subject: Illegal scaling, that is'nt illegal...
Date: 15 Dec 2009 01:50:01
Message: <web.4b273165d6d77fe7da6353d60@news.povray.org>
Hi people,
I've just made an animation with some _wanted_ zero-scalings in some frames.
Do anybody know a way to tell PovRay to scale the objects to zero, instead of
scaling them to one, and give me heaps of error messages?
Holger
Subject: Re: Illegal scaling, that is'nt illegal...
Date: 15 Dec 2009 03:01:49
Message: <4b27426d@news.povray.org>
H. Karsten wrote:
> Hi people,
> Holger
Hi Holgar,
out. The best you can do is scale very, very small (0.0000001?).
Best Regards,
Date: 15 Dec 2009 03:40:00
Message: <web.4b274b27c9eeb80dda6353d60@news.povray.org>
Well this would be maybe an option for the version 4.
Date: 15 Dec 2009 06:11:50
Message: <4b276ef6$1@news.povray.org>
LOL but seriously why do you want to scale things to zero? If I want to
show something getting larger from nothing I initially translate it out
from a small value.
Best Regards,
Date: 15 Dec 2009 07:35:06
Message: <V8qHR9B1J4JLFw+w@econym.demon.co.uk>
>of view then using a “step jump” translate it into view and scale
>it up from a small value.
If we're talking about zero in all three dimensions, then it would be
efficient to put all the objects inside if statements, and skip the
parsing and rendering if the scale is zero. Perhaps using a macro that
accepts an object and a scale factor if there are many such objects to
be handled.
However, the warning and the defaulting to 1.0 happen if only one of the
dimensions is scaled to zero. Perhaps Holger wants the objects to be
scaled infinitely thin, like part of a plane. With the current
behaviour, if you try to scale an object infinitely thin in one
direction, the parser thinks you've missed that parameter and scales it
to 1.0.
I can imagine some of the ray intersection solvers having big problems
with objects that really do have zero thickness, because they're trying
to find points where the ray goes from outside to inside something, and
that doesn't really happen if the object has no thickness. [Note that
thin objects like planes don't have that problem because they consider
half the universe to be inside.]
I can also imagine compound objects, like unions, suffering from
coincident surface artefacts wherever two components with different
textures overlap.
Mike Williams
Gentleman of Leisure
Date: 15 Dec 2009 16:00:12
Message: <4b27f8dc@news.povray.org>
>> to show something getting larger from nothing I initially translate it
>> out of view then using a “step jump” translate it into view and scale
> be handled.
Yes, that is a better way of doing it. I was thinking of my use of a
modeller that could not utilise #if or #case statements.
> to 1.0.
> textures overlap.
You put what I was thinking into a well defined statement. I wrote in
haste and now repent in leisure ;)
Best Regards,
Date: 29 Apr 2011 19:05:00
Message: <web.4dbb43a5c9eeb80db6f0ad930@news.povray.org>
"H. Karsten" <h-karsten()web.de> wrote:
> Hi people,
> Holger
Mayor Kravindish: This is illegal, you know.
