POV-Ray : Newsgroups : povray.animations : Re: Physics of Elastic Server Time
28 Sep 2024 22:15:53 EDT (-0400)
  Re: Physics of Elastic (Message 1 to 8 of 8)
Subject: Re: Physics of Elastic
Date: 20 Oct 2003 01:57:03
Message: <3f93792f$1@news.povray.org>
> My question: is the force excerted by the elastic linearly or
quadratically
> proportional to the amount you stretch it?
I believe the force is described by F = -kd, where k is some constant
describing how springy it is (higher k = greater force = stronger
springiness) and d is how far it's being stretched. So, yes, it's linear,
and the difference between a stretchy or rigid bit of elastic is the
constant k.
I forget what law this is... it's someone's "spring law" or something like
that. Learned it in high school Physics but I forget the guy's name...
 - Slime
 [ http://www.slimeland.com/ ]
Date: 20 Oct 2003 03:48:23
Message: <gp47pv07v5fs9o9miag0g0fa6ktkadnhiq@4ax.com>
On Mon, 20 Oct 2003 01:56:56 -0400, "Slime" <fak### [at] emailaddress> wrote:
Hook's law I & II
Regards
Date: 25 Oct 2003 12:10:59
Message: <3f9aa093@news.povray.org>
like
> Hook's law I & II
Yeah... that sounds familiar now you mention it...
OK, so the force exterted by the spring/elastic/whatever is simply some
multiple of the amount of distortion the thing undergoes? Cool - that's the
way I coded it! (Was initially inverse-square, like gravity... but I wasn't
sure that was physically correct...)
Thanks.
Andrew.
Date: 25 Oct 2003 12:20:11
Message: <el8lpvg154ksgktj0hc6askialg7sorkq4@4ax.com>
On Sat, 25 Oct 2003 17:07:50 +0100, "Andrew Coppin" <orp### [at] btinternetcom>
wrote:
>Cool - that's the way I coded it!
Yes, it is linear up to the limit of elasticity IIRC
Regards
Date: 25 Oct 2003 17:40:34
Message: <3f9aedd2$1@news.povray.org>
...that being the point at which is snaps, yes? ;-)
Thanks.
Andrew.
Date: 26 Oct 2003 04:00:19
Message: <n83npv4gp0begomhu3i3k1a8llahh8fh31@4ax.com>
On Sat, 25 Oct 2003 22:37:25 +0100, "Andrew Coppin" <orp### [at] btinternetcom>
No, IIRC It is the point where the material either stops being elastic or stops
having a linear deformation.
A picture(graph) is worth a thousand words.
http://has.ied.edu.hk/has/forum/phy/messages/23.htm
Regards
Date: 26 Oct 2003 06:24:54
Message: <3f9baf06$1@news.povray.org>
stops
Mmm... if only certain lecturers I met has such good handwriting ;-)
But seriously... that's more detail than I need for my simulation.
Interesting to know though. (I'm ever curiouse...)
Thanks.
Andrew.
Date: 30 Oct 2003 03:22:00
Message: <tkh1qvcnvlvd4bjd47i0u5gqkui7amr2oh@4ax.com>
On Sun, 19 Oct 2003 21:55:45 +0100, "Andrew Coppin"
<orp### [at] btinternetcom> wrote:
>Any hints on how the real physics works would be appreciated.
Others already mentioned Hooke's Law, I will just add minor but
important details.
Hooke's Law relates stress, strain and Young's modulus of elasticity.
Stress is absolute (not mathematically speaking, but physically
speaking). It is measured in N/m^2 can be basically considered to be
equivalent to pressure. Note that the denominator represents area,
i.e. a cross-section, so for uniform cross-sections (like a bar) it
can directly represent force. Stress is a tensor but for simple 1-D
problems can be treated as a numeric value.
Strain is a relative quantity (this is important) and shows how much
the object has "stretched". Technically, it is a tensor, like stress,
but the case of long, thin objects can be treated as one-dimensional
and thus purely algebraic. Strain is defined as (L - L_0)/L_0 or in
words, the change in length (positive if stretching, negative if
compressing) divided by the original length.
Peter Popov ICQ : 15002700
