POV-Ray : Newsgroups : povray.animations : Martian air/space defense installation Server Time
23 Mar 2026 01:02:31 EDT (-0400)
  Martian air/space defense installation (Message 1 to 8 of 8)
Subject: Martian air/space defense installation
Date: 11 Jun 2019 16:57:04
Message: <5d0015a0@news.povray.org>
My first animation of some complexity.
"Long after the last war, some of the martian defense installations are
still operational and without any crew left, now working in fully
automated mode."
https://www.youtube.com/watch?v=VWg1xsw5BCc
Rendered with PovRay 3.8.0-alpha
No radiosity, because that was flickering badly between the frames. Here
an early attempt with radiosity.
https://www.youtube.com/watch?v=HZM_lhW_FKQ
The radiosity code could not really make up its mind where to put the
light ...
Some of my PovRay works:
https://www.deviantart.com/antarasol/gallery/42758766/3D
Subject: Re: Martian air/space defense installation
Date: 11 Jun 2019 19:45:00
Message: <web.5d003c669ec211ca4eec112d0@news.povray.org>
> automated mode."
Well that's some pretty impressive work!
There must be a sizable amount of code, and you must have rendered quite a few
frames  :O
> light ...
Yeah - I could see that being tricky.
Have you tried using that rad_def.inc file as a starting point?  Maybe get
something that's slow but good, and then tweak it.  Because with all the
radiosity settings, that's gonna be challenging to do from scratch.
Date: 12 Jun 2019 17:15:07
Message: <5d016b5b$1@news.povray.org>
Thanks!
> frames  :O
800-some frames. Most of the models I had made for prior projects
already. So the biggest task was to make the cannons aim properly. Once
I had to learn all that math, but meanwhile I had forgotten quite a lot
again ...
I still can't get the math right for predicted fire if the target move
across rather than towards the fortress.
>> light ...
I think at one point I tried, but for my scenes which actually use
radiosity I tried to figure out good values on my own. I guess I should
check the include file again. It probably was made with more knowledge
than I have.
But that will have to wait for the next animation project.
I also need to look into video editing and how add a soundtrack to the
animation. So next step will be to find an easy to use and still
powerful video editor for Linux.
Date: 12 Jun 2019 17:45:00
Message: <web.5d0172009ec211ca4eec112d0@news.povray.org>
> again ...
Well that's not too bad...
I hear ya on the math - I've been there many many times myself.
I'm sure it's nothing we haven't solved before.   Post your issue.  We provide
the counseling, you provide your own medication ;)
I had great success with Audacity.  I was able to do a pretty good animation of
the Hellraiser box with some sound effects.   My Linux Mint software manager
shows that it's available, so maybe give it a go and see what you think.
Date: 12 Jun 2019 18:28:18
Message: <5d017c82$1@news.povray.org>
Found a free soundtrack to use (
https://opengameart.org/content/last-stand-in-space ), so here is the
new version with some sound:
https://www.youtube.com/watch?v=dJyOwumENDk
Date: 12 Jun 2019 18:53:52
Message: <5d018280$1@news.povray.org>
I know the basics ... take the movement vector of the target, estimate
the distance and the time of the bolts to fly, from that calculate the
point where the target will be after that time if it continues moving as
it used to.
Now, to get that into formulas that actually work in the scene file,
that is the problem and my head is not made for that.
Found something called Openshot. That is nice and easy to compose video
and audio. To actually make or edit the sound effects audacity sure is
nice. I've used it in the past to edit a few recordings of mine.
Is your animation online somewhere? I'm curious :)
Date: 12 Jun 2019 20:20:00
Message: <web.5d0195e99ec211ca4eec112d0@news.povray.org>
It is now.   I just posted it in p.b.a:
http://news.povray.org/povray.binaries.animations/message/%3Cweb.5d019356fb906fe54eec112d0%40news.povray.org%3E/#%3Cweb
It could probably use some updating...  :O
Date: 14 Jun 2019 18:23:18
Message: <5d041e56$1@news.povray.org>
> automated mode."
New version with some sound effects and more flash!
https://www.youtube.com/watch?v=gNCAz89cDw8
