POV-Ray : Newsgroups : povray.animations : Tales from a Renderfarm Server Time
1 May 2024 20:09:49 EDT (-0400)
  Tales from a Renderfarm (Message 1 to 7 of 7)
Subject: Tales from a Renderfarm
Date: 12 Feb 2017 02:44:39
Message: <58a01267$1@news.povray.org>
I added some BorderChars to my animation, between the 40-55 second marks.
http://www.buckosoft.com/tteoac/
tl;dr
I wanted to add some BorderChars to the credits of my animation.
This was a good excercise to actually use povclipse2.  I am pleased with
that; editing in povclipse2 is superior to pvengine.  Pvengine still has
a huge leg up on in-program integration with the render engine.
But it is so nice to say "show me a clickable list of all occurrences of
'StuGuitarExplodeStart' in all files".  My goal is to get back to my
mushroom-cloud-in-the-kitchen explosion. Anyway...
So I upgraded my farm's povray and then whined that my i7 is slower than
my i5s.  I went back to 3.7.1-alpha.8353331, which ran 100K frames for
me in the past, and still my i7 is slower.  Perhaps M$ is punishing me
for failing to free upgrade from Win8.1 to Win10. [1] ;)
I was annoyed when 8353331.exe crashed. twice. Of course, Windows
doesn't just terminate the program. No, it puts up a "checking for a
solution" dialog and then sits there.  So there is a 10 hour frame
(instead of 45 minutes) that will forever skew my stats.  I am now
running 3.7.1-alpha.8451792.  I will update to beta.3 when that is released.
I realized that once upon a time I said, "I can't wait to see a 1080p
version of my animation!",  but I was so happy with the 720p-30fps
version that I never did that.  So I started that 1080p job up. I'm
irked because my farm was idle for a year and could have been doing that
job.  I estimate 5-6 months to render it.
Immediately, I notice that my i7 is running twice as fast as my i5 on
the old, non BorderChars work.
So huh, it is BorderChars that is slow on my i7. I never could have
guessed something scene-specific could do that.
I got my first test results from 1080p-30fps.  I tried 60fps and 40fps
but the x.264 encoder laughed at me.  Hmm, there is very very slight
video tearing at the motion borders. This is especially noticeable
during slow movement.  Err, I wonder if I should kill it and start again
at 23.976fps.  That's the bluray standard, anyway.
Bleh, yes. I will kill it and start over. It's only a week's worth of
renders.  I will take this time to upgrade the farm's povray again.
I visualized povray's git history and chose origin/master (SHA
71c1415e). This is the best tag that has the utf8 fix, and I believe it
makes more sense for me to run this version over a year old version. I
know it's not a proper tag...  Internally, I called this beta.2a .
So the farm is updated, the frames are deleted, I am cranking through
the credits at 3358 frames per hour. (Once I open that door, it will
slow down to 30-60 minutes a frame @ 1920x1080)
dik
[1] At the time, OpenVPN didn't run on win10 and that is a critical
program for me.
Subject: Re: Tales from a Renderfarm
Date: 12 Feb 2017 05:28:52
Message: <58a038e4$1@news.povray.org>
Am 12.02.2017 um 08:44 schrieb dick balaska:
Prepare to want to upgrade your farm /again/ in about a week or so ;)
Date: 15 Feb 2017 12:25:00
Message: <web.58a48dd04b911216ae7df010@news.povray.org>
Hi there, I'm not sure exactly what you're describing but if you identify a
problem with BorderChars I'll be interested to know about it in case it's
something that can be fixed.
I did notice you're using FontVariationNumber 28 with the sample interior
object. (It looks great in your animation!) The wavy interior object renders
extremely slowly due to the use of so many sphere_sweeps. You can speed it up a
little by changing the setting of "#local DeltaTheta = 30;" to 45. This will be
perfectly acceptable for your scene.
Dave Blandston
Date: 15 Feb 2017 21:21:18
Message: <58a50c9e$1@news.povray.org>
Am 2017-02-15 12:20, also sprach Dave Blandston:
i5 = 3.2Ghz, 4 cores
i7 = 3.4Ghz, 4 cores, 8 threads.
So the i7 is a wee bit faster.  Also, 4 cores means the chip can do 4
things at once.  The i7 has 2 threads per core; it can sort-of do 8
things at once, but 2 threads share each FPU, I expect waiting for the
FPU to be involved.
In practice, I see the i7 average running about 80% faster than the i5.
(Looking at the Christmas tree, 26 minutes for i7 vs. 43 minutes for i5.)
But those scenes with BorderChars, the i7 is actually *slower* than the
i5.  I would think even if a thread is always waiting on the FPU, it
should still be minimally 6% (34/32) faster than the i5.
I can't imagine anything you could do different. It's just SDL.  The
issue has to be deep in the optimization code of the M$ compiler.
Or ... I blame clipka.
Thanks!  My problem now is, I did those 3 shots with BorderChars and
then it goes back to regular boring white characters and my brain says
"wtf, fix it, dude".
> Regards,
> Dave Blandston
dik
Date: 16 Feb 2017 04:50:00
Message: <web.58a5759e4b911216ae7df010@news.povray.org>
OK I understand now. I thought maybe you had found a bug that I missed. Thank
goodness you didn't!
Dave Blandston
Date: 16 Feb 2017 10:32:07
Message: <58a5c5f7$1@news.povray.org>
Am 16.02.2017 um 03:21 schrieb dick balaska:
> FPU to be involved.
I think it is realistic to expect hyperthreading to give about 15% more
pixels per unit of time.
I tend to blame it on different cache sizes. Or different number of CPU
clock ticks required to execute particular instructions. Or differences
in the CPU clock. Or in the branch prediction. Or in the instruction
pipeline depth. Or... well, I guess you get the picture: CPU performance
is an utterly complicated topic.
Date: 25 Feb 2017 14:26:25
Message: <58b1da61$1@news.povray.org>
Am 2017-02-12 02:44, also sprach dick balaska:
I now have 3.5 minutes of 1080p video (175MB).  I'm not loving the
motion. When paused, it looks gorgeous on my 24" 1920x1200 screen, but
movement is jerky. I notice it especially doesn't like when a line of
solid color moves against another solid color (you know, typical
computer animation stuff). My 720p version in full screen VLC stands up
pretty well to it.  The stills aren't as crisp, but the motion is
superior. *sigh*
dik
