POV-Ray : Newsgroups : povray.animations : Error: Final Frame 0 is less than Start Frame 1049 Server Time
10 Jun 2026 16:30:12 EDT (-0400)
  Error: Final Frame 0 is less than Start Frame 1049 (Message 1 to 7 of 7)
Subject: Error: Final Frame 0 is less than Start Frame 1049
Date: 15 Nov 2011 18:15:43
Message: <4ec2f29f$1@news.povray.org>
Just wanted to render 1050 pictures for a scene.
One notebook from 0 to 1049
The other from 1049 to 0
Hope in 12 hours, they have finished somewhere in the middle
But seems POV does not like this idea.
Subject: Re: Error: Final Frame 0 is less than Start Frame 1049
Date: 16 Nov 2011 04:10:01
Message: <web.4ec37ca9153ef325ae2687f0@news.povray.org>
If I understand you correctly, you want to distribute the rendering between your
computers?
In which case you could use Subset_Start_Frame = 0 Subset_End_Frame = 524 for
your first computer, and Subset_Start_Frame = 525 Subset_End_Frame = 1049 for
your second computer in your ini file.
Have a read of this, too:
http://wiki.povray.org/content/Documentation:Reference_Section_1#Animation_Options
Provided there isn't too much variation in the content of your scene, both
computers (assuming they are pretty much the same spec) should finish at about
the same time. If not, you can of course adjust the subset start/end.
Also, make sure the assumed_gamma is the same for both computers, otherwise the
output files will appear different, if I understand gamma correctly.
Regards, D103
Date: 16 Nov 2011 04:31:56
Message: <4ec3830c$1@news.povray.org>
> computers?
I used in the past weeks up to 5 computers to render
different scenes.
In this case, it's not so easy, because the first
300 pictures contain time consuming reflexion and transparency effects
One notebook is a 1,3 GHZ ULV, the other a 2,3 GHZ
So it was difficult to quess, where would be the half.
So I had the idea, that they could met somewhere in the middle,
whereever the middle is
Date: 16 Nov 2011 10:30:21
Message: <4ec3d70d$1@news.povray.org>
Povray is not megapov.
> different scenes.
Instead of meeting in the middle, you could use +STPn
(Same as Frame_Step=n) to split the load.
On first machine, +KFI0 +KFF1049 +SF0 +STP5
On second machine +KFI0 +KFF1049 +SF1 +STP5
On third ...      +KFI0 +KFF1049 +SF3 +STP5
On fifth ...      +KFI0 +KFF1049 +SF5 +STP5
For your two systems' case, it obviously translate to
On first machine, +KFI0 +KFF1049 +SF0 +STP2
On second machine +KFI0 +KFF1049 +SF1 +STP2
(+STP apply to 3.7RC3 (or later) version of povray, not the 3.6)
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 16 Nov 2011 12:08:16
Message: <4ec3ee00$1@news.povray.org>
>> different scenes.
Can I assign more or less CPU-cernels for a task?
I did not change to 3.7, because it's somethimes better,
that only one cernel calculates with POV,
and the rest of the notebook is free for other tasks.
Roland Mösl
Date: 16 Nov 2011 13:15:23
Message: <4ec3fdbb$1@news.povray.org>
Le 16/11/2011 18:08, Roland Mösl nous fit lire :
Yes, +WTn : n number of rendering threads.
Date: 16 Nov 2011 14:21:04
Message: <4ec40d20@news.povray.org>
Indeed it doesn't.
You might want to submit this as a feature request on
http://bugs.povray.org.
