POV-Ray : Newsgroups : povray.animations : Where is the failure Server Time
2 May 2024 19:14:57 EDT (-0400)
  Where is the failure (Message 1 to 6 of 6)
Subject: Where is the failure
Date: 15 Nov 2011 03:43:50
Message: <4ec22646@news.povray.org>
#declare terra_class = union
   sphere { <0,0,0> 100 }
   sphere { <70,0,-70> 8 rotate <0,0, 15> }
   sphere { <70,0,-70> 8 rotate <0,0, 75> }
   sphere { <70,0,-70> 8 rotate <0,0,135> }
   sphere { <70,0,-70> 8 rotate <0,0,195> }
   sphere { <70,0,-70> 8 rotate <0,0,255> }
   sphere { <70,0,-70> 8 rotate <0,0,315> }
   torus { 95 20   rotate <90 0 0> }
   texture { t_metall }
I thought the smaller spheres should be 45% visible on the biger sphere,
but they are not.
I can not find my failure
Subject: Re: Where is the failure
Date: 15 Nov 2011 04:07:52
Message: <4ec22be8@news.povray.org>
> but they are not.
Where is your camera?
They are visible to me when my camera is:
  perspective
  location <-0.891,7.168,-594.751>
  up y
  right 1.333*x
  angle 33.000
  sky <-0.000,1.000,-0.020>
  look_at < 0.449, 18.943, 0.102 >
Regards
Date: 15 Nov 2011 13:00:48
Message: <4ec2a8d0$1@news.povray.org>
>> but they are not.
> camera {
> perspective
> up y
> right 1.333*x
> angle 33.000
more in the - in the z axis, here the szene
was for a 12 second scene, where 4 Perry Rhodan style spaceships
fly, Earth and Moon in the background
BTW, it's so different from SF movies.
In SF movies are spaceships always lighted from all sides to
be good visible.
#declare t_metall = texture
   pigment { color red 0.51 green 0.69 blue 0.70 }
   finish
   { brilliance 8.0
     phong 1.0
     phong_size 80
     reflection 0.75
     ambient 0.01
   torus { 92.5 20   rotate <90 0 0> }
// 2011-11-15 change scale from m to km
   scale <0.001, 0.001, 0.001 >
#declare start_point = -499950;
#declare speed = 6;
object { terra_class translate < 0.6, 0.1, start_point +  0 - clock *
speed> }
object { terra_class translate <-0.6,-0.1, start_point +  5 - clock *
speed> }
object { terra_class translate < 0.2,-0.1, start_point + 10 - clock *
speed> }
object { terra_class translate <-0.2, 0.1, start_point + 15 - clock *
speed> }
object
{ sphere  { <0,0,0> 12757/2 }
   pigment { image_map { png "map-earth.png" map_type 1 interpolate 2 } }
   finish  { ambient 0 }
   rotate  < 0, -30, 0 >
   translate <-8000,0,0>
}  // object
object
{ sphere  { <0,0,0> 3467/2 }
   pigment { image_map { png "map-moon.png" map_type 1 interpolate 2 } }
   rotate  < 0, 90, 0 >
   translate <3500,0,-380000>
}  // object
light_source { <-149000000, 0, 0> color <1 1 1> } // light_source
light_source { <-149000000, 0, 0> color <1 1 1> looks_like { sphere {
<0,0,0> 1350000/2 color <1,1,1> } } } // light_source
camera
{ location <0, 0, -500000>
   direction <0 0 1>
   up <0 1 0>
   sky <0 1 0>
   right <16/9, 0, 0>
   look_at <0 0 0>
   angle 4
}  // camera
Date: 15 Nov 2011 15:13:25
Message: <4ec2c7e5@news.povray.org>
You will usually run into numerical problems when attempting
to model meter-sized objects in a solar system scale. You can
avoid such problems by modelling the small objects near the
origin at the meter scale and then faking the rest by using
planets and stars that are too close but also too small.
Also, having multiple light sources at the same position
doesn't seem to be useful. Note that the brightness is not
limited to 1 and using color rgb 3 will work just fine.
Date: 15 Nov 2011 15:21:22
Message: <4ec2c9c2$1@news.povray.org>
It is looking good.
Did you know that you do not need three light sources but can have one
light source with brightness greater than one?
color <3 3 3 > or color <1 1 1> * 3
> be good visible.
Artistic licence. :-)
Using that you could add a very little ambient to your planets to give a
hint of the darkside.
Regards
Date: 16 Nov 2011 22:27:30
Message: <4ec47f22@news.povray.org>
A single light_source with rgb 3 will also be about 3 times faster than
those 3 light_source with rgb 1.
In the first case, you only do a single illumination/shadow test.
In the second case, you need to do 3 of those: One for each lights.
