POV-Ray : Newsgroups : povray.animations : What Video Codec best for Animations Server Time
3 May 2024 00:20:18 EDT (-0400)
  What Video Codec best for Animations (Message 1 to 3 of 3)
Subject: What Video Codec best for Animations
Date: 10 Nov 2011 08:28:35
Message: <4ebbd183$1@news.povray.org>
I am just making a video
1280x720   16:9     30 frames per second
The big question is, what Video Codec
is best for output.
I make much use of
#declare Nature_t_Madow = texture
{ pigment
   { bozo
     turbulence 0.3
     color_map
     { // dry gras
       [0.000 0.300  color red 0.40 green 0.90 blue 0.00
	            color red 0.30 green 1.00 blue 0.00]
       // normal gras
       [0.300 0.900  color red 0.30 green 1.00 blue 0.00
                     color red 0.20 green 1.00 blue 0.00]
       // green from flowers
       [0.900 1.001  color red 0.20 green 1.00 blue 0.00
                     color red 0.05 green 0.95 blue 0.00]
     }  // color_map
   }  // pigment
}  // texture
to give surfaces some structure.
For the mixing of the video, I use
Magix Video Deluxe 2008.
I can not test all codecs, because only a limited
number of Codecs can be taken.
Please some advice
Subject: Re: What Video Codec best for Animations
Date: 10 Nov 2011 15:13:13
Message: <4ebc3059@news.povray.org>
> is best for output.
> I make much use of
> { pigment
> { bozo
> turbulence 0.3
> color_map
> { // dry gras
> // normal gras
> } // color_map
> } // pigment
> } // texture
Regardless what Codec, it's flickering
where are to hard contrasts.
before  I used GEMINI_t_Aluminium for the photovoltaic frame,
now GEMINI_t_Frame to reduce contrast.
Hope this reduces the flickering when the lines with the
frames move in the video
#declare GEMINI_t_PV_Silizium = // normal silizium photovoltaik
texture
{ pigment { color red 0.40 green 0.00 blue 0.60 }
   finish
   { brilliance 8.0
     phong 0.8
     phong_size 16
     reflection 0.1
     ambient 0.1 + Nature_m_ambient_add
   }  // finish
}  // texture
#declare GEMINI_t_Aluminium =
texture
{ pigment { color red 0.51 green 0.69 blue 0.70 }
   finish
   { brilliance 8.0
     phong 1.0
     phong_size 80
     reflection 0.5
   }  // finish
}  // texture
// 2011-11-10 video output shows flickering at the frames
//            of the photovoltaic. So try to reduce
#declare GEMINI_t_Frame =
texture
{ pigment { color red 0.408 green 0.552 blue 0.560 }
   finish
   { brilliance 8.0
     phong 1.0
     phong_size 80
     reflection 0.3
   }  // finish
}  // texture
Date: 10 Nov 2011 16:09:44
Message: <4ebc3d98@news.povray.org>
  Any codec implementing H.264 is usually a safe bet. (Although with some
inputs it may require some tuning of the compression parameters to get a
good result.)
