POV-Ray : Newsgroups : povray.animations : Object animated with camera following the movements Server Time
30 Apr 2024 03:10:35 EDT (-0400)
  Object animated with camera following the movements (Message 1 to 5 of 5)
Subject: Object animated with camera following the movements
Date: 25 Nov 2009 05:00:01
Message: <web.4b0cff4fa6e1ad0d27eef15b0@news.povray.org>
I want to do an animation of an object which moves in the space with non linear
trajectory and I want the camera to follow the movements, but I can't do this,
because when I change the "location" and "look_at vectors", the perspective
changes suddenly; i've tried to use the "sky" statement, but I don't exactly
know how it works and if it helps me.
To do an example, if I want do move the camera from:
x = 0
y = 0
z = 0
to
x = 10
y = 5
z = 12
pointing always the same point with a parabolic trajectory, which parameters
have I to give to my camera statement? How can I rotate the camera in the space?
Subject: Re: Object animated with camera following the movements
Date: 25 Nov 2009 07:45:16
Message: <4b0d26dc@news.povray.org>
You were on the right track with the sky statement.
Sky <(sin (radians(A)), (cos(radians(A)), 0>
Where A is the angle in degrees.
Best Regards,
Date: 25 Nov 2009 08:29:55
Message: <4b0d3153@news.povray.org>
> changes suddenly
  Changing the location and look_at vectors doesn't change the perspective
of the camera. You should be more precise about what is it that you want to
do and what is the undesired effect you are getting.
Date: 25 Nov 2009 09:54:32
Message: <4b0d4528@news.povray.org>
"Giuela" <mau### [at] elsagdatamatcom> wrote in message
news:web.4b0cff4fa6e1ad0d27eef15b0@news.povray.org...
>linear
> this,
> perspective
> exactly
I don't know if this wil help, but I had some luck doing a "fly-through"
kind of animation by first defining a spline for the camera path, then
setting the location property of the camera equal to Spline(0.95*clock) and
the look_at property equal to Spline(0.95*clock+0.05) or some such (the math
keeps the location and look_at points from coinciding during the animation).
That way, the camera was always looking at a point along it's path a few
frames into the future. It doesn't let you do banks or barrel rolls, but it
might be useful. In my case, the path was roughly parallel to the ground,
with only gentle changes along the Y axis, so I didn't need to adjust the
"up" property at all for the look I wanted. The camera did turn a little bit
at the corners, which gave a pretty good effect. Overall it was a little
like mounting a camera on the front of a roller coaster and looking ahead of
the turns.
I think you could compare the angle between a vector pointing back in time
[say, Spline(0.90*clock)] from the current clock position to a vector
pointing ahead in time (at the look_at position), and bank the camera in
that direction to give a more "airplane" type of feel to the turns. I'd have
to experiment to see what has the right look, but I think if you just
rotated the camera along the axis of the vector pointing backward by the
amount by which the angle of the two vectors varies from 180 degrees, it'd
look pretty good.
Here's an example (using pretty much random spline points):
// -w720 -h405 +a0.01 +am1 -j +fn -ua +kff96
// 24 fps animation
#declare FlyThrough =
    spline {
        cubic_spline
        -0.250, < 1.000, 1.000, 2.000>,
         0.000, < 2.000, 1.125, 3.000>,
         0.250, <-1.000, 1.000, 2.000>,
         0.500, <-2.000, 0.900, 1.000>,
         0.750, < 0.000, 1.000, 1.500>,
         1.000, < 0.500, 1.100, 1.750>,
         1.250, < 1.000, 1.000, 2.000>
    location    FlyThrough(0.95*clock)
    look_at     FlyThrough(0.95*clock+0.05)
    right       image_width/image_height*x
light_source { 360*<1,1,-1> rgb 2 }
sky_sphere { pigment { gradient x color_map { [ 0 rgb 0 ] [ 1 rgb 1 ] } } }
plane { y, 0 pigment { checker color red 1 color blue 1 } }
Jack
Date: 25 Nov 2009 11:24:05
Message: <4b0d5a25$1@news.povray.org>
How many frames do you use? If there is not enough frames, it will look
as if the camera changes sudently.
Do you want the camera to move behind or in parallel to the object? Or
do you want a fixed camera that points at the moving object?
> x = 0
> y = 0
> z = 0
> to
> x = 10
> y = 5
> z = 12
For that, you can use (sample using a straight path):
camera{location<10,5,12>/clock look_at Somewhere}
//Moves the camera leaving it always looking at the sme point.
camera{location Somewhere look_at <10,5,12>/clock}
//Static camera that follows a moving point.
camera{location<10,5,12>/clock look_at<10,5,12>/clock+<10,5,12>}
//This is a camera looking forward as it moves.
Changing the sky vector tend to tilt the camera. I don't think that's
what you want.
The best way, is to use the clock to change the location or the look_at
point the same way as you move your object. You can add some offset
value to place the camera some distance away from your moving object.
You change both if you want the camera to follow a path parallel to that
of the target object.
Another way, is to never change the location and look_at, but to rotate
and translate the camera. Make the translate the last statement of the
camera definition.
Sample:
#declare Position = [here, you calculate the translate applied to your
object]
// The value of "Position" is used to place the moving object.
camera{location Loc look_at Position}
// "Position" is also the look_at location.
// The object is defined at the origin.
You can take a look at the "splinefollow.pov" in the "animations" folder
that comes with the distribution. It demonstrate a complexe case where
you follows a spline where several objects are moving. It includes
banking of the camera in the curves.
