POV-Ray : Newsgroups : povray.animations : Can mencoder make an animation that plays on my TV? Server Time
20 May 2024 03:51:24 EDT (-0400)
  Can mencoder make an animation that plays on my TV? (Message 1 to 4 of 4)
Subject: Can mencoder make an animation that plays on my TV?
Date: 9 Oct 2008 13:50:00
Message: <web.48ee43786eb96ebe401d7400@news.povray.org>
I've done some searching both here and on the greater web to identify an answer
to this question.  I honestly didn't think it'd be this hard, but I guess it
is.
I have a Buffalo LinkTheater box at home connected to my television.  It will
attach to DLNA servers and play files.  I watch downloaded television shows
this way and it works pretty well.  The only files that haven't worked were
corrupted.
I want to watch my new animation on my television.  I can't find the right
settings for mencoder that will generate a file that has no artifacts and no
color defects.  The files look just fine on my PC, for what it's worth.
Things I've tried:
http://www.mplayerhq.hu/DOCS/HTML/en/menc-feat-vcd-dvd.html -- 14.8.5.2
This made blocks and had color defects, but played.
http://gentoo-wiki.com/HOWTO_mencoder_divx_to_dvd -- widescreen
This didn't play at all.
http://atomized.org/2005/03/converting-divxxvid-avi-to-dvd-with-ffmpeg/ --
Keef's comment
This one also played poorly.
Any suggestions?
Subject: Re: Can mencoder make an animation that plays on my TV?
Date: 9 Oct 2008 18:05:01
Message: <48ee800d$1@news.povray.org>
> is.
> corrupted.
> Things I've tried:
> Keef's comment
> Any suggestions?
I've had good luck with xvid and a constant quantizer when I don't care
about file size.  For example:
mencoder mf://'*.png' -mf fps=25:type=png -ovc xvid -xvidencopts
fixed_quant=2:autoaspect -ofps 25 -o video.avi
You can try 3, 4 etc, the higher the number generally means the lower
the quality.  I don't believe it is a good idea to use 1.  Hope this helps.
// The Mildly Infamous Blue Herring
#include"functions.inc"isosurface{function{-f_strophoid(x/2-.45,y,
z*3,1,1.2,1,1.5)-.05}contained_by{box{<-2.1,-1,-1/3>,<1.4,1,1/3>}}
max_gradient 12inverse hollow pigment{rgbf 1}interior{media{samples
8 emission<3,80,150>/255density{crackle metric 1color_map{[0rgb 6]
[.03rgb 0][1rgb 0]}scale<1,2,1>warp{turbulence<.5,.75,.5>}scale 1/
3}}}translate z*3}
Date: 10 Oct 2008 12:00:01
Message: <web.48ef7b9d5bc169b2401d7400@news.povray.org>
> > is.
> > corrupted.
> > Things I've tried:
> > Keef's comment
> > Any suggestions?
This worked perfectly.  Thank you so much, I'll be doing it this way from now
on.
> 3}}}translate z*3}
Date: 5 Oct 2010 10:20:01
Message: <web.4cab336c5bc169b2b8f6b920@news.povray.org>
Just burn it to a DVD and play it with a DVD player! :-P
