POV-Ray : Newsgroups : povray.animations : Add object to camera Server Time
9 May 2024 02:24:24 EDT (-0400)
  Add object to camera (Message 1 to 3 of 3)
Subject: Add object to camera
Date: 5 Jul 2008 15:25:00
Message: <web.486fc9aab0c652322bb066f70@news.povray.org>
I have a camera flying along a spline, and now I would like to add a pair of
"headlights" that move along with it.
Is there an easy way to do it or would I be forced to solve that with an
additional spline?
Is there a way to set the orientation of the headlights so that they will always
be below the camera, parallel to the bottom "image border"?
Also, is it possible to set the (tilt) angle of the camera in relation to the
spline? I am thinking of a loop-shaped spline. Currently, the camera will
with the up vector, but I'd like to have that automated (if the loops are
generated automatically).
Yes, this is not all about animation, but animation was still the subcategory I
thought would fit best, so I nevertheless hope that some of you can help me
here.
Subject: Re: Add object to camera
Date: 5 Jul 2008 16:54:40
Message: <486fdf90@news.povray.org>
"philguy" <phi### [at] googlemailcom> wrote in message
news:web.486fc9aab0c652322bb066f70@news.povray.org...
> of
> additional spline?
> always
> the
> manually
There's not enough information to give a definitive answer, so I'll start by
assuming the loop of track is flat and that you want the camera to lean into
the corners in the way that a motorcyle would. If the track is moving up and
down a bit you could calculate the amount to lean the camera by just
ignoring the y component of the direction vectors for the purposes of this
calculation.
Given the direction vector of the spline at the camera position and the
direction vector of the spline a short, but constant distance ahead you can
use VAngleD to work out the angle between their horizontal components. You
can take this as being roughly proportional to the amount you should lean
the camera off the vertical. That is to say that the sharper the turn to the
left or right, the more the camera would lean over.
To get the 'up' vector you can project the vector 'y' onto the plane defined
by the camera direction vector using VProject_Plane (this gives you a vector
at right angles to the camera direction vector that will always point
roughly upwards) then rotate the result around the camera direction vector
by the amount you want to lean the camera over using the vaxis_rotate
function.
You can add a directional light (a spotlight) under the camera by
subtracting the normalised 'up' vector (multiplied by whatever distance you
want) from the camera position. You can specify a point_at position as being
the light position plus the camera direction vector so that the light shines
out parallel to the camera. To get a pair you'll need to displace their
positions at right angles to the plane defined by the camera 'up' and
'direction' vectors (see vperp_to_plane).
Hope that helps,
Chris B.
Date: 6 Jul 2008 00:10:08
Message: <lXuinDBMWEcIFw+T@econym.demon.co.uk>
>additional spline?
>will always
>here.
The demo scene that's included in the distribution does all that
/scenes/animations/splinefollow/splinefollow.pov
The first Aircraft is attached to the camera.
The camera itself is offset from the first Aircraft by
        translate <0,0.4,0.4>
otherwise it would be inside the body of the Aircraft and wouldn't see
anything interesting.
splinefollow.pov doesn't move the light source, but the same technique
that's used for moving the camera works. Try removing the existing light
sources from a copy of splinefollow.pov and adding this one at the end.
light_source {< 0,0.4,0.4>,
      color 1.0
      spotlight point_at <0,0.4,1> radius 10
      Spline_Trans (MySpline, clock*11, y, 0.5, 0.5)
Using the non-first-person view shows the lighting effect better.
Using the first-person view shows the camera tilt.
Mike Williams
Gentleman of Leisure
