POV-Ray : Newsgroups : povray.animations : find the exact camera position (from video/images) Server Time
26 Jun 2024 15:17:13 EDT (-0400)
  find the exact camera position (from video/images) (Message 1 to 4 of 4)
Subject: find the exact camera position (from video/images)
Date: 28 Jul 2007 12:04:36
Message: <46ab6914$1@news.povray.org>
I am searching a program that is able to find the exact or even close camera location
(and
look_at) of a real video I record with my camera. Then I want to use these exported
values(txt) in a pov-ray file and render some objects onto the videoimages.
I don't know if there is a program, but I think there could be one, that compares the
images
of the video and find some points/lines to create a location and look_at for the
camrea in
3d space.
Thanks,
Benjamin
Subject: Re: find the exact camera position (from video/images)
Date: 10 Aug 2007 10:43:54
Message: <46bc79aa$1@news.povray.org>
"Benjamin" <nan### [at] webde> wrote in message
news:46ab6914$1@news.povray.org...
> Hi,
> camera location (and look_at) of a real video I record with my camera.
> Then I want to use these exported values(txt) in a pov-ray file and render
> compares the images of the video and find some points/lines to create a
> location and look_at for the camrea in 3d space.
> Thanks,
> Benjamin
Hi Benjamin,
I'm not aware of a program that will do this. There are programs that can
analyse images, looking for 'common' points. These are usually pretty
sophisticated programs designed for particular categories of images (e.g.
face recognition). I think that most movie production of this type uses kit
to track the position and orientation of the camera when it's filming the
real world so that the camera position and orientation can be reproduced in
a virtual environment where the artificial objects can be rendered.
The general problem that you describe has two parts and both are quite
tricky.
The first you mention is to find common points. It's easy to underestimate
the difficulty of this because we can spot common points on two similar
images so easily ourselves, but it's really quite a complex task for an
image processing system to do unless you're able to introduce a distinctive
object into the images that can make position fixing easier e.g. brightly
coloured light sources that can easily be located by scanning the pixels of
the two images for a colour in a particular range. This problem can be
exacerbated by poor quality and low resolution images. Also, tiny movements
in the camera between frames or lighting changes can cause the same point on
an object to be represented differently on the image.
Even if you can identify common 2D positions on two images, establishing
where they may be in space relative to the camera depends upon you having
certain knowledge about the content of the image. Scale is a big problem
because it's very difficult to tell whether you're seeing a small object up
close or a large object at a distance. This is why movie makers can film
something on a model constructed on a table top and make it seem like it's a
huge real-world sized scene. Once again, one approach is to introduce
something into the scene that you are filming of a known size and shape. So
long as you know the camera settings used (ie the zoom) then you should be
able to get enough information to use trigonometry to calculate the camera
position relative to the known object.
Chris B.
Date: 26 Sep 2007 03:50:01
Message: <web.46fa0ed09eb3b11a907f6c410@news.povray.org>
This mostly falls under the topic photogrammetry, usually using perspective
geometry. There is one free (open source I believe) camera calibration
package made by a University professor...can't remember the details and
can't find the link. If you search enough, you may be able to find it.
What you're asking is possible though. It's used with "augmented reality"
applications. For instance, mapping a little 3d object to stand on a piece
of paper with a few special markers on it. If you google augmented reality,
you'll find many many interesting videos about it.
I know I haven't helped you much, but, it may help you find something. If
you do, I'd love a link to it. ;-)
Date: 29 Sep 2007 18:55:31
Message: <46fed7e3@news.povray.org>
> Hi,
> Thanks,
> Benjamin
Rune knows >_>
http://runevision.com/show.asp?id=51
http://runevision.com/3d/anims/hologram.asp
Most interesting info at the bottom of second link.
