POV-Ray : Newsgroups : povray.animations : Animation statistics analysis, help needed. Server Time
26 Jun 2024 11:41:37 EDT (-0400)
  Animation statistics analysis, help needed. (Message 1 to 3 of 3)
Subject: Animation statistics analysis, help needed.
Date: 24 Feb 2006 06:23:38
Message: <43feecba$1@news.povray.org>
While running an animation I've used the following line
Statistic_File=Floorplan_F.txt, in the 'ini' file.
I would like to have a graph of the render times, to see what frames take up
the most time. Bonus points if I can selectively pick other interesting
stats as required.
What would be the best way to scan the resulting text file and extract this
information on a Win98 system?
Subject: Re: Animation statistics analysis, help needed.
Date: 24 Feb 2006 07:17:12
Message: <43fef948$1@news.povray.org>
"StephenS" <sshonfield(at)ottawa(dot)net> wrote in message
news:43feecba$1@news.povray.org...
> up
> stats as required.
> this
> Stephen
Hi Stephen,
The best way depends on where your skills lie, what software you have
available and how many times you are going to need to do it.
You need to:
1 - Pick out the values you need.
2 - Convert the 'hours', 'minutes', 'seconds' format into a single figure.
3 - Plot the results.
If you only need to do it once or twice I'd recommend using a decent text
editor to select the lines you want. Then use columnar selection to select
the column of data containing the hours and paste it into a spreadsheet
column. Then do the same with the minutes and seconds and use a cell
calculation to work out a single figure for the seconds for each frame. Use
the spreadsheet graphing functions to draw your graph.
Otherwise pick a language and parse the file. I like Rexx as a nice user
friendly scripting language (Regina is a free Rexx interpreter for Windows).
With Rexx you could pick out the values you need in just a few lines of code
and do the sums to work out a number of seconds. In fact with most languages
you wouldn't need many lines of code to pick out the values. You can write
out the totals into a Comma Separated Variable file and load it into a
spreadsheet or use it with POV-Ray to draw a spline.
Chris B.
Date: 24 Feb 2006 17:00:11
Message: <43ff81eb$1@news.povray.org>
Use
I should have said I was useing POV-Ray 3.6.1b, which includes the total
seconds. This is the aproach I'll start with.
This would be a better solution. I'm hoping to have 15 to 20 short
animations based on the same general scene, with the shortest being 800
frames minimum.
