POV-Ray : Newsgroups : povray.animations : Need help fast! Server Time
3 Jul 2024 04:15:12 EDT (-0400)
  Need help fast! (Message 1 to 4 of 4)
Subject: Need help fast!
Date: 24 Feb 2005 13:25:00
Message: <web.421e1adf3a10b8eeca937fd00@news.povray.org>
Hi all. I haven't used POVRay in several years, and now I find myself in the
position of needing help fast.
I teach physics at the North Carolina School of Science and Math, and have
some students working on a project concerning the physics of snowboarding.
They've created a model that simulates a downhill snowboard run, saving the
data in a plain text file containing x and y position, angle of attack of
the board, and direction of motion for successive timesteps.
I've created a POVRay source file of a snowboarder on an incline, and know
how to modify the source file to rotate and translate the character.
However, I need to know how to take the data generated by the simulation
and somehow plug it into the POVRay scene file and make a series of
rendered images and stitch them together and make an animation.
I did this sort of thing 5 or 6 years ago, but I was using an entirely
different platform, and it's been a long, long time. Can anyone give me the
quickest and dirtiest way to take our dataset and produce an animation?
Time is very short.
For what it's worth, we're running on Windows XP.
Thanks for any help you can provide.
Dr. Michael Owen
mow### [at] ncrrcom
Subject: Re: Need help fast!
Date: 24 Feb 2005 16:04:58
Message: <ET0SbAAzFkHCFwqA@econym.demon.co.uk>
>Time is very short.
Convert your data to a format where the numbers are separated by commas,
ensuring that there is a comma at the ends of the lines. (POV doesn't
see the end of line characters, so it always needs the commas.)
1,2,3,0.5,
2,3,4,0.6,
3,4,5,0.7,
Then use POV to read the data with #fopen and #read, like this
#fopen DATA "data.txt" read     // open the file
#declare F=0;                   // start a counter
#while (F < frame_number)       // loop
  #read (DATA, X,Y,Z,Angle)     // read a chunk of data
  #declare F=F+1;               // increment counter
POV restarts from the beginning of the file for each frame, so this code
reads and ignore the entries that correspond to earlier frames.
Mike Williams
Gentleman of Leisure
Date: 25 Feb 2005 13:25:00
Message: <web.421f6cde2e505a1ca937fd00@news.povray.org>
Thank you, Mike. I eventually dug around enough in some example scene files
and the manual and came up with almost the same solution:
  #fopen Dataset "fort.23" read
  #declare Index = 1;
  #while(Index <= frame_number)
  #read (Dataset,Time,X_Pos,Y_Pos,Beta,Phi)
  #local Index = Index + 1;
  #fclose Dataset
But I really appreciate the response. The other part that was difficult was
getting it to actually animate, i.e. render more than one frame. This is
NOT adequately covered in the manual, in my humble opinion.
Thanks for your help,
Mike Owen
> >Time is very short.
> 1,2,3,0.5,
> 2,3,4,0.6,
> 3,4,5,0.7,
> #end
> Mike Williams
Date: 25 Feb 2005 13:37:05
Message: <421f7051@news.povray.org>
was
Did you see section "2.3.8  Making Animations"? It seems to cover it pretty
thoroughly and I found it just now by typing "animation" into the index tab
of Windows Help.
 - Slime
 [ http://www.slimeland.com/ ]
