POV-Ray : Newsgroups : povray.animations : Photons Server Time
27 Sep 2024 20:19:05 EDT (-0400)
  Photons (Message 1 to 4 of 4)
Subject: Photons
Date: 26 Feb 2004 20:09:47
Message: <403e98db@news.povray.org>
Hi guys,
I am currently working on a scene with a sphere floating in some water. It
is in it's infant stages, and is more a learning experience than an attempt
at a decent image.
I have the water looking decent nowm, thanks to Chris' page. But I can't get
photons to work. Can I grab some help?
Here is my code:
#include "functions.inc"
#include "Radiosity.inc"
#include "textures.inc"
global_settings
  max_trace_level 5
  /*radiosity
    Radiosity_Settings(1,true,true)  \\This is a macro I made.
  photons
      spacing 0.01
      save_file "photons.dat"
camera
    location <0,10,0>
    look_at <0, 10, 100>
sky_sphere
    pigment
      color rgb <0.75,0.98,1>
light_source
 <  0,  3000,    -3000>
 color White
 photons
      reflection on
      refraction off
light_source
  <0,3000,3000>
  White
  shadowless
#declare watermaterial = material
  texture
     pigment
        color rgbf <1, 1, 1, 1>
      finish
        ambient 0.0
        diffuse 0.0
        reflection
          0.3,1.0
          fresnel on
        specular 0.4
        roughness 0.003
      /*normal
        bozo 0.3
        scale 5
      normal
        function
          f_ridged_mf(x, y, z, 0.1, 3.0, 7, 0.7, 0.7, 2)
        } 0.8
        scale 3
   interior
     ior 1.3
     media
      scattering { 2 <0.5, 0.65, 0.4> }
#declare waterbase = plane
  y,-1
  pigment { color Black }
#declare watertop = plane
  y, 0
  material {watermaterial}
#declare water = union
  object {waterbase}
  object {watertop}
#declare Ball = sphere
  <0,0,50>,5
  pigment { color Red }
#declare Box = box
  <-10,-0.001,-10>,<10,0.001,10>
object
  water
object
  Box
  photons
    target 0.5
    reflection on
    refraction off
object
  Ball
  photons
    reflection on
    refraction off
Subject: Re: Photons
Date: 26 Feb 2004 20:32:46
Message: <403e9e3e$1@news.povray.org>
attempt
> at a decent image.
get
First: povray.animations might be the wrong group for this kinda post, cause
there's nothing that has to do with animations in your problem...
Second: your box and your ball don't have proper textures for the photons to
interact with. POV shoots the photons but they will only appear if the
box/ball actually reflect or refract the photons. The Box doesn't have a
texture at all, whereas the ball is just plain red, both don't have any
finish with reflection. Hence, no photons get reflected off of them.
Now, if you want photons to appear on the ball and box, e.g. reflections off
the water, then the water would have to be the target.
I've haven't rendered the scene and I didn't look too much where objects are
placed in relation to each other, but without a proper texture, ball and box
won't work with photons. That's all covered with the Docs, so maybe you
should go back to those and read them once again.
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 26 Feb 2004 21:10:15
Message: <403EA7B4.5F001F27@tag.povray.org>
povray.newusers would be the appropriate group for this type of question.
Ken Tyler
Date: 26 Feb 2004 21:53:09
Message: <403eb115$1@news.povray.org>
"Ken" <ken### [at] tagpovrayorg> wrote in message
news:403EA7B4.5F001F27@tag.povray.org...
cause
Maybe it was going to animated later.  ;-)
Not only is the Box object not reflective (or anything else), it just
doesn't make sense what it's doing there. Maybe was to be a container for
the media? Those two planes are obvious anyhow, for top and bottom surfaces
while having separate textures. If photons are to hit the bottom plane
though, it really shouldn't be black. Maybe media scattering was only thing
in mind and not for there to be dappled light reaching the bottom. Sorry if
I am speculating too much.
So... there *is* a water material and the object its applied to. It ought to
be the thing with a photons statement most of all.
Doing the following might be correct if the box is intended as basin for
water:
  -y,-1
  pigment { color rgb 0 }
  y, 0
  object {waterbase}
  object {watertop}
#declare Box = intersection {
box
  <-100,-1.001,25>,<100,0.001,100>
object
  water
object
  Box
  photons
    target 0.5
    reflection on
    refraction off
 hollow // for media to show
That red Ball doesn't need photons block unless to specify 'collect off' for
it or it gets a reflection added to the texture, like Tim was saying. My
changes here make the whole scene different so it's still not clear to me
what was intended by it (the Box mainly).
Bob H.
http://www.3digitaleyes.com
