POV-Ray : Newsgroups : povray.animations : camera-spline behaves weird Server Time
27 Sep 2024 20:19:53 EDT (-0400)
  camera-spline behaves weird (Message 1 to 7 of 7)
Subject: camera-spline behaves weird
Date: 13 Feb 2004 12:55:51
Message: <402d0fa7@news.povray.org>
Hi everybody!
i'm currently working on a scene with a car driving along a street, changing
the lane and then turning left at a intersection. i tried using a
quadratic_spline, cubic_spline and a natural_spline for the cam-movement but
the problem is that all three of them don't produce an accpetable path
across the intersection. it's not like a part of a circle but has some
unneccessary movements to the left and the right in it (am i confusing you?
sorry...). so basically i need to know how to create a spline that produces
a path similar to a quarter of a circle.
    Marc
Subject: Re: camera-spline behaves weird
Date: 13 Feb 2004 13:05:13
Message: <g14q20t197ugso0e550s3p246gvn721stg@4ax.com>
On Fri, 13 Feb 2004 19:00:30 +0100, "Marc Roth" <mar### [at] rothconsultcom> wrote:
Use something like this not tested macro. It approximates circle with linear
spline. Use Accuracy between 0 and 1
#macro QuarterOfCircleSpline(Center,Radius,Accuracy,Angle)
  #local S=spline{
    #local Counter=0;
    #while (Counter<Angle)
      Counter (vrotate(x*Radius,y*Counter)+Center)
      #local Counter=Counter+Angle*Accuracy;
    Angle (vrotate(x*Radius,y*Angle)+Center)
  spline{S}
Adjust further to your needs.
ABX
Date: 13 Feb 2004 21:43:21
Message: <402d8b49@news.povray.org>
>   #local S=spline{
>     #local Counter=0;
>     #end
>   spline{S}
> #end
> ABX
Hi ABX,
thanks a lot for your answer, but i'm afraid i don't quite understand it
as i'm not very familiar with macros. i understand that
QuarterOfCircleSpline is a macro that creates a spline named S which
looks like a quarter circle with a radius of Radius and the center
Center. the accuracy is understandable as well, the smaller it is, the
smaller are the steps in which the circle is drawn. but what is angle
for? do i use S(clock) for the cam-movement? it doesn't seem to work
quite right as i get an error: "Parse Error: Expected 'object or
directive', spline found instead" in the line with spline(S).
ciao,
	Marc
Date: 14 Feb 2004 01:37:56
Message: <qSfiYGAQHcLAFwGN@econym.demon.co.uk>
Wasn't it Marc Roth who wrote:
>Hi everybody!
Here's a spline that does a quarter circle turn
#declare MySpline = spline {
   natural_spline
    0,     <-1, 0, 0>,
    0.001, <-0.999, 0, 0>,
    0.5,   <-1+sin(pi/4),0,1-sin(pi/4)>,
    0.999, <0,0,0.999>,
    1,     < 0, 0, 1>
The second and fourth control point force the direction of the tangent
at the endpoint. The third control point stops it taking a shortcut.
Unfortunately, this may lose you some of the advantages of using a
spline, and you might as well drive along an actual circle.
Mike Williams
Gentleman of Leisure
Date: 16 Feb 2004 05:55:02
Message: <688130l1ck9mep3n63u2defqlehenk4kg9@4ax.com>
On Sat, 14 Feb 2004 03:47:58 +0100, Marc Roth <mar### [at] rothconsultcom> wrote:
> but what is angle for?
Sorry, as I said it was not tested. I wrote it initialy to create only quarter
of circle but finally made macro for making arc of any angle in circle.
It is supposed to return spline. You have assign it to another variable and
use that variable like splines you tested previously.
ABX
Date: 18 Feb 2004 10:26:01
Message: <40338409$1@news.povray.org>
> [something about making a spline which goes a quarter of a circle]
hm, i tried something myself and it worked out. i simply looked at the
formula for a circle which is
x^2 + y^2 = r^2
x and y are the coordinates and r is the radius of the circle. you can
make it more flexible by changing it to
(x-a)^2 + (y-b)^2 = r^2
now it's a circle with radius r around a center with the coordinates <a,b>
if you solve this equation you get:
y = sqrt( r^2 - (x-a)^2 ) - b
this can be used rather easy in a #while loop to create the
controlpoints for the spline.
bye,
	Marc
Date: 16 Jun 2004 22:05:01
Message: <web.40d0fbc3ae1c7fd1e2f575410@news.povray.org>
> Hi everybody!
>     Marc
Are you using colefax's spline.mcr package?  Can you provide the data points
and options used to create the spline?  Where along the path (between what
data points) does the problem occur?
I've been dealing with some spline problems that sound similar to yours.  My
data points should have described essentially straight line motion with
some rather lazy curves side to side, but spline.mcr seemed to want to add
a loop (yes, it reversed direction) in the middle of the spline.  To add to
the frustration, the loop was so squeezed in the side-to-side direction it
wasn't apparent during the spline preview.  I think part of my problem was
using data points with very irregular separation.  In the straighter
sections data points were separated by many tens of units; in the more
curved sections they were separated by only a few units.  This, I think,
allowed an opportunity for the calculated spline to loop in the large gaps.
 Adjusting the spline tension seemed to help, but I'm not sure why.  I hope
to get some help with my problem (see my recent post regarding spline
spacing), also.
Good luck!
Glenn C.
