POV-Ray : Newsgroups : povray.animations : How to make the animation in pov-ray work Server Time
29 Jun 2024 08:21:24 EDT (-0400)
  How to make the animation in pov-ray work (Message 1 to 10 of 23)
Subject: How to make the animation in pov-ray work
Date: 1 Jan 2004 14:26:32
Message: <3ff47468$1@news.povray.org>
I'm just getting into pov-ray.  I've gone through the animation tutorial,
but can't get the tutorial object to move.  All there is, is a picture, no
animation.  How do I make the animation work?  I read that I'm supposed to
set the clock, but the tutorial is not really showing me how.  If some one
can, please help.  Thank-you.
Subject: Re: How to make the animation in pov-ray work
Date: 1 Jan 2004 14:55:30
Message: <3FF47BC8.759D077E@pacbell.net>
Take a look at the site below and visit the introduction page for a good
explaination of what you need to do -
http://www.puzzlecraft.com/cm/ClockMod.html
Ken Tyler
Date: 1 Jan 2004 14:59:06
Message: <3ff47c0a$1@news.povray.org>
Try something like this:
//This stays still
box {<-1, -1, -1>,<1, 0, 1> texture {pigment {color rgb 0.5}
finish {ambient 0.1 diffuse 0.9}}}
//This moves and changes colour
sphere {<-0.5 + clock, 0.15, -0.5 + clock>,0.15 texture
{pigment {color rgb <1, 0.25 + (clock * 0.5), 0.75 - (clock
* 0.5)>} finish {ambient 0.1 diffuse 0.9 specular 0.8
roughness 0.0001}}}
camera {location <0,5,-3> look_at <0,0.5,0>}
light_source {<10,10,-10> color rgb 1}
Render using (e.g.) +KFF50 in the "command line".
This will produce a sphere which moves steadily from <-0.5,
0.15, -0.5> to <0.5, 0.15, 0.5> throughout the 50 frames of
the animation, changing colour as it does so.  The variable
"clock" runs by default from 0 in the first frame to 1 in
the final frame, and will therefore allow movement or colour
change or whatever else you wish.
HTH.
Date: 1 Jan 2004 15:25:55
Message: <3ff48253@news.povray.org>
How do I change anything in the "command line"?  How do I turn the animation
on?
"Andrew" <ast### [at] hotmailcom> wrote in message
news:3ff47c0a$1@news.povray.org...
> //This stays still
> roughness 0.0001}}}
> HTH.
Date: 1 Jan 2004 15:36:02
Message: <3ff484b2@news.povray.org>
> on?
  You didn't specify your operating system. If you are using POV-Ray for
windows, there's a command-line field near the resolution dropdown menu.
Date: 1 Jan 2004 16:22:35
Message: <3ff48f9b$1@news.povray.org>
My operating system is windows.
news:3ff484b2@news.povray.org...
animation
> > on?
Date: 1 Jan 2004 16:35:39
Message: <3FF49342.D581E50F@pacbell.net>
> How do I turn the animation on?
Again, visit the site I linked to earlier. You will see that it explains this
question and more.
Ken Tyler
Date: 4 Jan 2004 21:20:01
Message: <web.3ff8c9766da14afe3a5fb9ba0@news.povray.org>
Click on Tools-->  Edit Master POVRAY.INI
In this ASCII text file, add the line:
Final_Frame=20
(or if it were commented out with a ;  then remove the ; infront of that
line) and save the .INI file.
Now render your image.
Greg M. Johnson
Date: 4 Jan 2004 22:19:51
Message: <3ff8d7d7@news.povray.org>
> Final_Frame=20
  That's the hard way of doing it, and not very advisable because from
that point on *every* scene you will render will be rendered as an
animation of 20 frames.
  Just writing +KFF20 on the textfield above the editor window will do it.
Date: 10 Jan 2004 11:20:02
Message: <web.4000256f6da14afe3a5fb9ba0@news.povray.org>
>> Final_Frame=20
That's not a workable solution for a serious animation project. One would
have a fixed number of final frames in the project and might want to look
at various different subsets as one tweaks different parts of the story.
Looking up and remembering the +KXYZ  switches, and retyping 3 to 4 of them
by hand for EVERY TEST RENDER is just so incredibly user-unfriendly.
Greg M. Johnson.
