POV-Ray : Newsgroups : povray.animations : Re: parsing and animations Server Time
6 Oct 2024 12:21:49 EDT (-0400)
  Re: parsing and animations (Message 1 to 4 of 4)
Subject: Re: parsing and animations
Date: 19 Mar 2002 12:26:46
Message: <72te9uckkf4r3ng463s22vc98nsn6kma5v@4ax.com>
On Tue, 19 Mar 2002 18:13:28 +0100, "Gallas" <e97### [at] efdlthse> wrote:
> it didn't have to re-parse the array for every single frame. Is this
> possible to achieve?
what is the reason of reparsing ? does it contain coordinates of objects ?
parse it once for first frame and output ready syntax to additional file. for
every next frame use this new file instead of parsing array.
ABX
Date: 19 Mar 2002 12:41:18
Message: <3c97783e@news.povray.org>
for
I'm not much of a hardcore pov-ray user (more or less the opposite).
My idea of making an animation is giving first_frame and final_frame the
right values in some .ini-file. When I do this I get the same parse time for
every frame.
And for the record, the array do contain coordinates of objects.
Actually it contains coordinates for objects during every frame of the
animation, so I can access it with frame_number.
Date: 19 Mar 2002 20:06:23
Message: <slrna9foks.1kb.bruce@pingouin.rez-gif.supelec.fr>
> every frame.
You should better try, if possible, to calculate each position with the clock
variable instead of having all of them in an array. (moreover, you could
easily change the number of frames of your animation). If you really need
to have all those values, put the value for each frame in a separate fil and
read only this one during animation
For exemple, rendering 100 frames, create 100 files called data_xxx.dat, where
xxx is the number of the frames the data are refering to. In your pov scene,
open only the right file (with frame_number), and catch the data from the file.
Hope it will help (and you understood my bad english)
	-- Bruce
Date: 20 Mar 2002 06:33:06
Message: <3c987372$1@news.povray.org>
where
scene,
file.
Of course. This will likely solve my problem.
Thanks.
