POV-Ray : Newsgroups : povray.animations : concat problem Server Time
6 Oct 2024 13:20:42 EDT (-0400)
  concat problem (Message 1 to 10 of 10)
Subject: concat problem
Date: 7 Feb 2002 16:24:41
Message: <3c62f099$1@news.povray.org>
I'm trying to use a Targa file in a height field. I'm calling the file via
the following string:
height_field {
tga concat("d:\\povray\\penfilter\\fig", str(1,-2,0), ".tga")
which I would expect to return
height_field {tga "d:\povray\penfilter\fig001.tga"
But I continue to get the message: Error opening TGA image. There are a
series of files in that directory called fig001.tga through fig100.tga, and
when I use the code:
by itself, the file renders.
I assume there is something wrong with the concat parameters (sorry, I don't
know how to use #debug), but the "-2" above should pad "fig1" with two
zeroes, as in:  "fig001"  correct?
Anyway, maybe it is something with the double quotes? Ultimately, I plan to
use a sequence of Targa files (all 100 of them) and wonder if I can use
str(clock*100,-2,0)
but would POV see "clock" as a text string, or is that a reserved string
that it will correctly see as the clock?
Please let me know if anyone has any specific suggestions.
Thanks very much,
Dennis
dhm### [at] mediaonenet
www.casdn.neu.edu/~dmiller
Subject: Re: concat problem
Date: 7 Feb 2002 16:43:28
Message: <3c62f500@news.povray.org>
Dennis Milller <dhm### [at] mediaonenet> wrote:
: I assume there is something wrong with the concat parameters (sorry, I don't
: know how to use #debug), but the "-2" above should pad "fig1" with two
: zeroes, as in:  "fig001"  correct?
  Nope. It makes the integer part 2 digits long with padded zeros if the
number is not big enough. That is, you get "fig01".
  Try with -3.
Date: 7 Feb 2002 17:05:55
Message: <3c62fa43$1@news.povray.org>
Yes! You are correct, and -3 works.
Next challenge:
I would like to read in a series of files starting with fig001.tga and
ending with fig100.tga
But whereas I would use "clock*100" in most cases, that does not work in the
string:
concat("d:\\povray\\penfilter\\fig", str(clock*100,-3,0), ".tga")
I assume the multiplier (*) is read as text? or maybe clock? (That may not
be true...) But could you suggest a way to read in the sequence of images
from 001 to 100?
Thanks again very much,
Dennis
news:3c62f500@news.povray.org...
don't
>   Try with -3.
x]
Warp -
Date: 7 Feb 2002 18:20:54
Message: <3c630bd5@news.povray.org>
You should learn to use the #debug stream to print what you are creating
to the console. That is, create the file name you want to open and print
this file name with #debug to see that it's correct. For example:
#declare Filename = concat(whatever);
#debug concat("Filename to read: ", Filename, "\n")
  This way you can check that what you are creating is correct.
  Anyways, your problem is that you are using clock*100. The first calue
clock gets is 0, and 0*100 = 0. That is, you are getting the number "000",
not "001".
  The easiest way of fixing this is to use frame_number instead of clock*100.
frame_number gets consecutive integer numbers starting from 1, and that's
exactly what you want.
Date: 7 Feb 2002 20:30:09
Message: <3c632a21@news.povray.org>
Okay. That's it.
Thanks again for your help.
I'll look into debug.
Best,
D.
news:3c630bd5@news.povray.org...
> not "001".
clock*100.
M()}}
Warp -
Date: 5 Sep 2002 12:19:54
Message: <B99D41EB.413B%fidel.viegas@artrecognition.co.uk>
in article 3c62fa43$1@news.povray.org, Dennis Milller at
dhm### [at] mediaonenet wrote on 7/2/02 11:02 pm:
> Next challenge:
> string:
why not use the frame_number?
that is:
concat("d:\\povray\\penfilter\\fig", str(frame_number, -3, 0), ".tga")
if you set your initial frame to 1 and your final frame to 100, you will get
fig001.tga to fig100.tga.
All the best
Fidel.
Date: 5 Sep 2002 12:20:37
Message: <B99D4218.413C%fidel.viegas@artrecognition.co.uk>
Sorry, I didn't notice it was an old message.
But, anyway it should help others.
All the best
Fidel.
> Next challenge:
> string:
> from 001 to 100?
> Dennis
> don't
>> Try with -3.
> x]
> Warp -
Date: 9 Sep 2002 06:53:13
Message: <B9A23B43.47D2%fidel.viegas@artrecognition.co.uk>
in article B99D41EB.413B%fid### [at] artrecognitioncouk, Fidel viegas at
fid### [at] artrecognitioncouk wrote on 5/9/02 5:16 pm:
>> Next challenge:
>> string:
> that is:
correction, it will generate fig1.tga to fig100.tga.
Fidel.
Date: 9 Sep 2002 07:26:51
Message: <3d7c857a@news.povray.org>
  Are you sure? A small test:
#declare Ind = 1;
#while(Ind <= 20)
  #debug concat("fig", str(Ind, -3, 0), ".tga\n")
  #declare Ind = Ind+1;
  This prints "fig001.tga" to "fig020.tga".
Date: 10 Sep 2002 19:58:33
Message: <B9A444E4.4845%fidel.viegas@artrecognition.co.uk>
in article 3d7c857a@news.povray.org, Warp at war### [at] tagpovrayorg wrote on
9/9/02 12:26 pm:
> #declare Ind = 1;
> #while(Ind <= 20)
> #end
You are correct, I used a 0 instead of -3 in str.
Apologies
Fidel.
