POV-Ray : Newsgroups : povray.animations : bad flickering Server Time
6 Oct 2024 14:24:21 EDT (-0400)
  bad flickering (Message 1 to 8 of 8)
Subject: bad flickering
Date: 4 Feb 2002 15:56:47
Message: <3c5ef58f$1@news.povray.org>
I'm trying, for quiet a time, to do a 25fps trailer base on a fly-by
rendered with PoV. But, I've always went up with a clip with an awful
flickering, it's like to see 2 pictures at the same time. I think I've tried
all th possible things,:
    - source in interlace, output in interlace
    - source in non-interlace, output in non-interlace
    - and all the possible combinaition
    - de-interlaced
    - 3:2 pulldown
    - etc...
It always end up the same : !!! FLICKERING !!!
Oh, I forget : I'm using TMPEnc to make a SVCD compliance MPEG-2, 480x576,
25fps. The animation is 12 seconds, with 300 frames, which makes it 25
fps...
Emmanuel
And remember, COOL is only three (3) letters away from FOOL.
Subject: Re: bad flickering
Date: 4 Feb 2002 16:55:04
Message: <3c5f0338@news.povray.org>
Do you use jitter?
Date: 4 Feb 2002 21:57:55
Message: <3c5f4a33@news.povray.org>
Probably some sort of Jitter. Maybe you specified jitter in something, like
an area light or media, or maybe the default AA jitter is doing it.
Crand will also do that, but I don't think anyone uses that anymore...
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 5 Feb 2002 05:46:42
Message: <3C5FB811.3B3D73D5@atosorigin.com>
Emmanuel Tatto wrote:
> Hi,
>     - de-interlaced
>     - 3:2 pulldown
>     - etc...
> fps...
Looks like you are doing Pal encoding, so 3:2 pulldown is really of no use
for you. (it was made for NTSC 29.97 vs Movie 24).
Which hardware are you using to display the Mpeg2 ?
 (Because I experimented with H+ on TV and some (! not all) sequences
 do generate flickering of the lower part (about 1/3) when view on TV)
With Pov image source at 25 fps, you should use progressive source and
progressive output (a.k.a non-interlaced).
Does the flickering appears in a low action or a high action part of the
movie ?
Have you enable VBR ? or are you still with CBR ?
What is bitrate when flickering occurs ?
Non Sine Numine
http://grimbert.cjb.net/
Puis, s'il advient d'un peu triompher, par hasard,
Date: 5 Feb 2002 16:29:20
Message: <3c604eb0@news.povray.org>
Yop, I'm using a RealMagic card to display on TV and Monitor the clip.
Well, I'm going to burn the SVCD and try on my DVD player to see if the
flickering's still there...
For complement : I'm using VBR, since CBR is bad crap on any DVD player ;
the flickering occurs at any bitrate, even at max 2.6MBit/s, which is the
max for SVCD standard, and the resolution is standard SVCD, i.e. 480x576,
for a PAL MPEG-2.
de news: 3C5FB811.3B3D73D5@atosorigin.com...
> > Hi,
tried
> >     - de-interlaced
> >     - 3:2 pulldown
> >     - etc...
480x576,
> > fps...
> movie ?
> Non Sine Numine
Date: 5 Feb 2002 16:31:02
Message: <3c604f16$1@news.povray.org>
No, I'm not using jitter or crand (I used to read a Help file when I'm
blocked ! ;-) )
3c5f4a33@news.povray.org...
like
> - Slime
Date: 5 Feb 2002 20:45:48
Message: <3c608acc$1@news.povray.org>
Not even the default AA jitter?
- Slime
Date: 7 Feb 2002 14:06:37
Message: <3c62d03d@news.povray.org>
ney !!!
3c608acc$1@news.povray.org...
> - Slime
