POV-Ray : Newsgroups : povray.animations : particle_system movie Server Time
28 Jul 2024 14:31:12 EDT (-0400)
  particle_system movie (Message 1 to 10 of 25)
Subject: particle_system movie
Date: 2 Jul 2000 10:00:54
Message: <chrishuff-922746.09010202072000@news.povray.org>
http://homepage.mac.com/chrishuff/mpovplus/multitex2 Movie.mov
It is a QuickTime movie demonstrating the new particle interaction and
emitter texturing features. It has two emitters whose streams of
particles merge into one.
Subject: Re: particle_system movie
Date: 2 Jul 2000 13:03:04
Message: <395f75c8@news.povray.org>
I get a "Not Found"-Error on this link ...
Marc-Hendrik
Chris Huff schrieb in Nachricht ...
>Christopher James Huff - Personal e-mail: chr### [at] maccom
>TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
>Personal Web page: http://homepage.mac.com/chrishuff/
>TAG Web page: http://tag.povray.org/
Date: 2 Jul 2000 13:26:31
Message: <395f7b47@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:395f75c8@news.povray.org...
Yep, same here.  Lights are on (home page is there) but nobody home.
Date: 2 Jul 2000 13:58:43
Message: <chrishuff-D31829.12585102072000@news.povray.org>
In article <395f7b47@news.povray.org>, "Bob Hughes"
I just tried it again, and it works fine. Make sure you get the
capitalization right, "multitex2 movie.mov" won't work. Otherwise...it
should work.
Date: 2 Jul 2000 14:28:19
Message: <395f89c3@news.povray.org>
> should work.
Most people aren't accustomed to having spaces in urls, Outlook will create
a clickable link for urls, but stops at the space.
This should work also (at lease for Windows/IE):
http://homepage.mac.com/chrishuff/mpovplus/multitex2%20Movie.mov
and Outlook won't choke on it.
Date: 2 Jul 2000 14:54:50
Message: <395f8ffa@news.povray.org>
"Jetlag" <bga### [at] microsoftcom> wrote in message
news:395f89c3@news.povray.org...
Thanks, I was putting a / in-between there and it hadn't occurred to me it was
meant to have a space.
Ok, seen it now.  The overpowering purple streamer pushing the yellow streamer
is great, the color mixing flickers about a lot but tough to say how it should
behave.  Except a mixing amount might be the way to go, you know, like hetero-
or homogeneously.  This animation seemed an blend of the two, if that makes
sense.  A better way to say it might be: if you had blue and yellow mixing to
just green or retaining their blue and yellow colors only.
Date: 2 Jul 2000 14:57:56
Message: <395f90b4@news.povray.org>
Got it, this space irritated me and OE.
Marc-Hendrik
Date: 2 Jul 2000 17:28:09
Message: <chrishuff-4C8DFB.16281802072000@news.povray.org>
In article <395f8ffa@news.povray.org>, "Bob Hughes"
> me it was meant to have a space.
Sorry about that, I will keep from using spaces in online files in the
future.
> streamer is great, the color mixing flickers about a lot but tough to
> say how it should behave.  Except a mixing amount might be the way to
> go, you know, like hetero- or homogeneously.  This animation seemed
> an blend of the two, if that makes sense.  A better way to say it
> might be: if you had blue and yellow mixing to just green or
The texture mixing can't really be helped...it is a blob.
Date: 2 Jul 2000 23:08:01
Message: <39600391@news.povray.org>
Interesting... Show me some more. :) Why didn't you announce this in
.general?
Date: 3 Jul 2000 11:06:31
Message: <chrishuff-C536BF.10064103072000@news.povray.org>
In article <39600391@news.povray.org>, "Tony[B]"
Later. Right now I am making some modifications which will allow much
more flexible animation and particle generation options. The
"custom_particle" feature is gone, for example, but now you should be
able to get particle information like position, radius, velocity, age,
etc. through functions, so you can do much more. And the whole system no
longer has to be recalculated each frame, you should be able to use the
persistent objects feature of MegaPOV to calculate only what is
necessary. And I plan on adding things like fluid types, particle
fission/fusion, custom inter-particle force profiles, low-speed impact
effects...
Some other modifications I have made already: collision detection is
much more accurate, and you can specify a texture on an
emitter-by-emitter basis(demonstrated by the animation).
> Why didn't you announce this in .general?
Er, well, I didn't think about it. I assumed anyone looking for an
animation would look in povray.animations.
