POV-Ray : Newsgroups : povray.animations : rotation and orbit ? Server Time
28 Jul 2024 16:16:35 EDT (-0400)
  rotation and orbit ? (Message 1 to 10 of 15)
Subject: rotation and orbit ?
Date: 22 Jan 2000 10:54:24
Message: <3889d2b0@news.povray.org>
I've managed to make animation of a rotating sphere. What I really want to
do is rotate a sphere on it's axis while it orbits another rotating sphere.
Generally I export the scene out of Moray and animate in POV-ray, if that
makes a difference.
I am hopeful someone can post an example of what the code would look like
for such a scene.
Thanks
dan
Subject: Re: rotation and orbit ?
Date: 22 Jan 2000 11:40:43
Message: <3889DCD6.6CA75E8B@pacbell.net>
> makes a difference.
> for such a scene.
> Thanks
> dan
 This is really very simple. The sphere that you want spinning and orbiting
needs to have it's spin applied before it is translated out to it's orbiting
position. The first sphere is the one that spins only on it's axis. The
second will spin on it's axis and orbit the first sphere.
sphere { 0, 1
  rotate y*360*clock
   pigment { checker color x*1 color z*1 scale .5 }
sphere { 0, 1
 rotate y*360*clock
  translate x*4
   rotate y*360*clock
    pigment { checker color x*1 color rgb 1 scale .5 }
  This very simple example shows how to make it spin one time on it's
axis and also rotate one time around the center sphere for one full
clock cycle. You just need to adjust the degrees rotation and the
direction you want it to orbit for the scene you are designing.
Date: 22 Jan 2000 12:33:48
Message: <3889E946.125F929C@pacbell.net>
Bob Hughes wrote:
> Here's my example, and only an example.  It's simplistic really,
You call that simplistic ?
Bob, you have become a declare freak and might want to seek professional
help soon.
<G>
Date: 22 Jan 2000 13:36:52
Message: <3889f8c4@news.povray.org>
Thanks ken,
this is what i endeded up with that seems to work. I imagine the axis are
different then your example because of the left/right handeness thing
between pov-ray and moray. Or maybe not. I am clearly a novice.
sphere { // Jupiter_Sphere
  <0,0,0>,1
  material {
    Jupiter_Tex
  scale 40.0
  rotate -360.0*z*clock
sphere { // Callisto__sphere
  <0,0,0>,1
  material {
    Moon_Tex
  scale 4.8
   rotate -360.0*y*clock
  translate  50.0*x
   rotate z*-360*clock
Ken wrote in message <3889DCD6.6CA75E8B@pacbell.net>...
to
sphere.
>> makes a difference.
>> for such a scene.
>> Thanks
>> dan
orbiting
>sphere { 0, 1
>  rotate y*360*clock
>sphere { 0, 1
> rotate y*360*clock
>  translate x*4
>   rotate y*360*clock
>Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
>http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
Date: 22 Jan 2000 15:02:45
Message: <388a0ce5@news.povray.org>
The method is simplistic, yes.  Putting a working (ha, yeah sure) example in was
probably a mistake, it was flawed the second time too.  Here's the corrected (?)
one:
light_source { <0,0,-500> color rgb <1.5,1.5,1.5>
camera
  location  <-5,5,-15>
  angle 25
  look_at   <0,-.5,0>
// approximations of Earth/Moon system (only a guess)
#declare NS1=<0,0,24>; // axial tilts [z here]
#declare NS2=<0,0,13>; // orbital inclination [11 degrees diff.?]
#declare OrbitPos1=<-.1,0,0>; // orbital distances (not real)
#declare OrbitPos2=<3,0,0>; // orbital distance [x here]
#declare Diam1=1; // sizes (not real)
#declare Diam2=.25;
#declare Rotate1=<0,28,0>; // days (not real) multiply this by Revolve#
#declare Rotate2=<0,1,0>; // orbit-coupled with Revolve#
#declare Revolve1=<0,1,0>; // orbits; same as Rotate2 (orbit-coupled)
#declare Revolve2=<0,1,0>; // [y is up coordinates]
#declare PlanetTex1=texture {pigment {marble turbulence 1
        color_map {[.33,.5 color rgb <0,1,0> color rgb <0,0,1>]}
         } rotate 90*z}
#declare MoonTex1=texture {pigment {spotted turbulence 1
        color_map {[.2,.25 color rgb <.5,.5,.5> color rgb <1,1,1>]}
         } scale .5}
 texture {pigment {radial frequency 12 // longitudinal lines
        color_map {[.1,.2 color rgbt <0,1,1,0> color rgbt <0,0,1,1>]}
         } scale 1} // 1 unit so already scaled ok
 texture {pigment {gradient y frequency 6 // latitudinal lines
#declare MoonTex1=
 texture {pigment {radial frequency 4 // longitudinal lines
        color_map {[.1,.2 color rgbt <1,1,1,0> color rgbt <0,0,0,1>]}
         } scale .25} // scale to fit
 texture {pigment {gradient y frequency 2 // latitudinal lines
#declare RotatingRevolvingSphere1=
 sphere {0,Diam1
        texture {PlanetTex1} // texture placed before movement
         rotate -360*Rotate1*clock rotate NS1 // axial tilt
          rotate 360*Revolve1*clock // counter-turn of orbit
         translate OrbitPos1 // needs to be opposite of other
           rotate -360*Revolve1*clock
          rotate NS2 // yes, NS2 here too, orbital tilt (E&M)
            } // orbit
#declare RotatingRevolvingSphere2=
 sphere {0,Diam2
        texture {MoonTex1} // texture placed before movement
         rotate -360*Rotate2*clock rotate 0 // axial tilt
          rotate 360*Revolve2*clock // counter-turn of orbit
         translate OrbitPos2 // needs to be opposite of other
           rotate -360*Revolve2*clock
          rotate NS2 // orbital tilt (E&M)
           } // orbit
object {RotatingRevolvingSphere1}
object {RotatingRevolvingSphere2}
Maybe I can get the second reply cancelled as well, it isn't good, and I'm not
saying this will be right either.  Best to render 100 frames at 320x240 res. to
check it out.
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3889E946.125F929C@pacbell.net...
| help soon.
| <G>
Date: 22 Jan 2000 15:15:41
Message: <388a0fed@news.povray.org>
thanks.
I have kinda gone in this direction. It is easier for me understand what is
happening. But i'll keep yours as a reference for when I'm more versed in in
pov-ray.
  <0,0,0>,1
  material {
    Jupiter_Tex
  scale 40.0
  rotate 360*z*clock
sphere { // Io_sphere
  <0,0,0>,1
  material {
    Io
  scale 3.36
  rotate 1080*z*clock
  translate  422.0*y
  rotate 1440*z*clock
sphere { // Europa_sphere
  <0,0,0>,1
  material {
    Europa_Tex
  scale 3.138
  rotate 720*z*clock
  translate  528.0*x
  rotate 1080*z*clock
sphere { // Ganymede_sphere
  <0,0,0>,1
  material {
    Ganymede_Tex
  scale 5.256
  rotate 720*z*clock
  translate  928.0*x
  rotate 720*z*clock
  <0,0,0>,1
  material {
    Callisto_Tex
  scale 4.8
  rotate 360*z*clock
  translate  1741.0*x
  rotate 720*z*clock
Bob Hughes wrote in message <388a0ce5@news.povray.org>...
in was
corrected (?)
>one:
>camera
>  location  <-5,5,-15>
>  angle 25
>  look_at   <0,-.5,0>
>#declare Diam2=.25;
>         } rotate 90*z}
>         } scale .5}
>#declare MoonTex1=
> sphere {0,Diam1
>            } // orbit
> sphere {0,Diam2
>           } // orbit
not
res. to
>check it out.
>Bob
>| help soon.
>| <G>
Date: 23 Jan 2000 13:21:38
Message: <3890466c.5820028@194.174.214.110>
Hi dcc, you recently wrote in povray.animations:
> makes a difference.
You may want to take a look at the animation plugin that works with
the latest version of Moray. Then you won't have to work in both GUI
and non-GUI environments.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 23 Jan 2000 22:27:24
Message: <388bc69c@news.povray.org>
Thanks Lutz
I did take a look at the animation plugin for the new moray beta but I
couldn't easily figure out how to automate the rotation aspects.
Lutz Kretzschmar wrote in message <389### [at] 194174214110>...
>> makes a difference.
>- Lutz
Date: 23 Jan 2000 23:32:14
Message: <388BD2E8.58786EEB@global2000.net>
What if the orbit is tilted?  The orbit of the Moon is tilted about 5.145
degrees.  Would that be incorporated if the Moon is rotated on its axis, tilted
over a little, translated, rotated 5.145 degrees and revolved around the
Earth?  What if a elliptical orbit is desired?
Brendan Ryan
> makes a difference.
> for such a scene.
> Thanks
> dan
Date: 23 Jan 2000 23:54:10
Message: <388bdaf2@news.povray.org>
All good questions. I haven't attempted any tilts or an ellipse orbit. The
tilt seems simple, but the orbit may involve a spline path or something. I
don't know if that can be done in moray.
this is as far as I have gotten.
http://www.cornillot.com/graphics.htm
dcc
Andrea Ryan <ary### [at] global2000net> wrote in message
<388BD2E8.58786EEB@global2000.net>...
tilted
> Brendan Ryan
