POV-Ray : Newsgroups : povray.animations : output question Server Time
28 Jul 2024 16:30:18 EDT (-0400)
  output question (Message 1 to 7 of 7)
Subject: output question
Date: 13 Dec 1999 18:09:48
Message: <3855A70C.CD446A79@ij.net>
If you want 10 animation images POV spits them out
in NAME00 throught NAME10. For 100 they come out
NAME000 through NAME100.
    All fine but CMPEG wants them NAME0 to NAME10 to
NAME99 ending at NAME100.
    OK, I created simple batch files to convert the
names.
    But I am wondering if there is either a way to get
POV to output what CMPEG wants or to make CMPEG eat the
POV output.
Subject: Re: output question
Date: 14 Dec 1999 04:09:52
Message: <8E9C66702seed7@204.213.191.228>
on commandline +kfi0 +kff9 gives you ten frames named in the way that cmpeg
likes.
Ingo
Date: 14 Dec 1999 04:56:20
Message: <38563E93.2E31A671@ij.net>
> likes.
Gratias. And would that be +kfi0 +kff999 for over a thousand frames?
Date: 14 Dec 1999 06:03:26
Message: <385623fe@news.povray.org>
cmpeg also can read a file with all the filenames. You can create this
file this way in DOS:
dir /b *.tga > images.lst
and this way in UNIX:
ls *.tga > images.lst
  See the documentation of cmpeg for more information.
Date: 14 Dec 1999 08:08:34
Message: <38564152@news.povray.org>
What you want to do is give CMpeg the correct parameter.
cmpeg frame%03d.tga animated.mpg
The %03d tells it to get frame000 to frame999 for example.  %02d  is for
double digits, %01d for single (0 to 9).  The zero is telling it to look for
zero buffered numbers as in 00 to 99 where the first digit starts out as 0.
I use a batch file myself, except simply for the running of CMpeg.  So I
only have to type:
  mpg frame%02 animated
at a DOS prompt to compile the "frame00.tga" to "frame99.tga" into a mpeg
called "animate".  The mpg.bat file contains a line saying:
 cmpeg %1d.tga %2.mpg
with a cd command before that to go to where I have CMpeg, since I don't add
everything to my PATH.  I never could get the "%0" to go inside the batch
file itself otherwise it would be even simpler.
"Matt Giwer" <jul### [at] ijnet> wrote in message
news:3855A70C.CD446A79@ij.net...
> names.
> POV output.
Date: 14 Dec 1999 21:48:57
Message: <38570199@news.povray.org>
> only have to type:
add
If you want to pass the literal string "%0" as a parameter to CMPEG you
probably need to add an extra percentage sign in the batch file, eg. cmpeg
%%0...  Otherwise the %0 is substituted with the first word on the command
line, ie. the name of the batch file itself.
My own CMPEG batch file follows Warp's suggestion:
@ECHO OFF
IF "%1"=="" GOTO Help
IF "%1"=="/?" GOTO Help
DIR %1 /B /ON > CMPEG.TMP
P:\CMPEG\CMPEG -v1 %2 %3 %4 %5 %6 %7 %8 %9 P:\CMPEG.CTL CMPEG.TMP Movie.mpg
DEL CMPEG.TMP
ECHO.
GOTO End
:Help
P:\CMPEG\CMPEG /?
:End
This lets me specify a set of frame files using a wildcard, as well as any
optional CMPEG parameters I might wish to use, eg:
   CMPEG FRM*.TGA -d1
Date: 14 Dec 1999 22:26:37
Message: <38570a6d@news.povray.org>
I'm fairly certain I tried to do just that before, although it was in vain
for some reason.  I remember now, the way it would be needed to be entered
kind of prevents the simple two parameter way I wanted to do it.
mpg frame 3 animated  (example of command-line) would be  cmpeg %1%%0%2d.tga
%3.mpg  in the batch file.
See?  Would require three instead of just two.  I know, ridiculous aren't I?
Though I thought I had at least tried this before and it might have fouled
up somehow, not sure.
I like Nieminen's file list idea too, so maybe I'll switch to that since it
certainly reduces the command line entry.  Which occurs to me, noticed you
typed out the .TGA when you can put it in the batch as well, just like
Nieminen had said.
"Chris Colefax" <cco### [at] geocitiescom> wrote in message
news:38570199@news.povray.org...
> > only have to type:
mpeg
> add
batch
> @ECHO OFF
Movie.mpg
> DEL CMPEG.TMP
> ECHO.
> GOTO End
> :Help
> P:\CMPEG\CMPEG /?
> :End
>    CMPEG FRM*.TGA -d1
